Odie
I feel very lucky to have learned basic woodturning skills back in the early 1980's. Back then, there was no such thing as a swept back grind.....or, the Ellsworth grind, among other swept back grind shapes attributed to other turners. Back then, all new turners were taught the "traditional" gouge grind. The traditional gouge grind has probably been around for 100 years, and it's something you rarely see these days.....simply because the momentum of the woodturning herd has all but made it extinct.
In my opinion, the traditional grind (if shaped well) is more versatile and can produce a finer cut in difficult places, than any of the swept back grinds.
For those who are unaware of the traditional gouge grind, it's produced using the "V-arm" of the Wolverine jig. The Wolverine makes it easy, but I suppose other turners have made their own simple jigs to produce this grind. It's not complicated, and because of that, it's also very easy to learn.
I suspect there will be a great pushback from the herd here, but this is because the traditional grind is seldom seen anymore.....virtually nobody is teaching it.....and very few turners are using it. Awareness of the traditional grind these days is practically non-existent, except for a few turners who have been turning for close to 40, or more years.
Just to be clear here, I first began using the swept back grind about 35 years ago, during a time when most turners were first learning this new approach to gouge grind shapes. I eventually was using the swept back grind exclusively. Back then, I transitioned from the traditional grind to the swept back grind......prior to transitioning back to the traditional grind about 20 years ago. When I transitioned back to the traditional grind, it was after I had been turning for a couple decades.....so, at that time, I had some experience under my belt to evaluate the usefulness of the various grinds that were available and being taught.
Right now, I don't think I have a single gouge that still has a swept back shape.....and, that Vari-grind jig for the Wolverine is gathering dust!
=o=
=o=
