I was looking at several projects down the road that I will need an indexing wheel on the wood lathe. I looked on YouTube and there are several do it yourself projects for making an index wheel for the wood lathe. I was considering printing out a 360 degree template and applying it to a disc that would be mounted between the lathe spindle and adjustable chuck. I searched thru some old 10" saw blades and found a 180 tooth blade that should provide a good solution for this application. All I need to do is drill or machine the center of the blade to fit over my lathe spindle and make a pin that will lock onto the teeth at any location around the circumference of the saw blade.
