"It's just a bit of wood." How do you deal with turning fails?
These would be too big for my little "failure" bowl, but an interesting concept.
Well, duh, just fail another bowl. :)
Earlier today I ordered this one to try:
It might also look great with my crystal ball. Every time someone asks me an unanswerable question in a Zoom meeting I hold up the crystal ball.
I have that one to use with a faceted crystal ball. Problem is the viewer has to be directly overhead for full effect. There is little to no effect from the side unless the room is totally dark. I think the light would have to come in at an angle.
Here is a handful of quarts river rock about 1" to 1.5" around, harvested yesterday from the rock ballast bed on a flat warehouse roof. It is lit up from below with a 500 lumen Streamlight LED flashlight. This flashlight on high will fry your retinas. 500 lumens through the rocks looked nice, much better than my photo below. Anyway, I choked down the exposure on my phone camera to simulate what it looks like without blowing out the shot.
The lens of the flashlight is .5" dia., with the bezel surrounding it around 3/4"+. I think to be effective, a hole through the bottom of a bowl will need to match +/- the lens diameter of the light sourse. This sends all of the light output up into the bowl. A 2" or 3" lens sitting under a 3/4" diameter hole limits most of the light's shine potential. And then... if the hole is too much bigger, then stones will poke out the bottom of the hole and hit the light. Balancing act.
The 500 lumen setting on the flashlight lit up the rocks brightly, much brighter than my photo shows (which would have been totally blown out if I didn't choke down the camera). The dim 50 lumen setting of the flashlight makes the rocks look like a night light in a dark room. All light manufacturers have lumen ratings, and candella, too (2 different things), all over the place in their marketing, but if you find a small, cord-powered pod light with a smaller lens (like John's offering above), you stand a good chance of making a neat little project.
You'd need a pretty small hole, but I can imagine marbles being a nice illuminating media, too. (Unless you can find a package of larger shooters. Young folk can research playing/shooting marbles after class. They're not just used for slingshot ammo, after all.) Any larger translucent or transparent man-made stones or beads should suffice.
Maybe it just needs a diffuser or a small piece of fresnet lens to spread out the light. Or shining up through a small hollow turned vase holding some white peacock feathers. I'll experiment - I have lots of optical elements salvaged from various equipment and cameras over the years.
Ever been right at the finish line on a turning project only for it to crack, blow out the bottom of a bowl with your gouge, or it splits beyond repair?
You’ve done the prep work, mounted the blank, shaped the form, and then… it’s gone. All that time and care, undone in a split second. We’ve all been there; I was just there today! It’s a gut punch!
I remember watching one of Richard Raffan’s videos a while back. He was turning a bowl, and right in the middle of the process, it flew apart on the lathe. What struck me wasn’t just the mishap, it was how calm he was about it. He paused, looked at the mess, and said something offhand that completely changed how I see those moments.
It was just a little comment, but it stuck with me. So much so that I made a sign to keep near my lathe as a reminder that: “It’s just a bit of wood.”
That simple phrase has helped me keep perspective and stay grounded when things don’t go according to plan. Because in the end, every mistake is just another part of the process!
Nope... never had that happen....NOT:oops:
Years ago I found antique "marbles" at a small antiques and oddities shop in Virginia, each a beautiful transparent glass sphere with a unique color, no internal patterns, various sizes. Some were far too big to use in a marbles game, must have made been for something else. I just bought three but since wished I'd picked up all the guy had. Next time...
The large marbles were targets to shoot at with the other marbles. Similar to playing HORSE in basketball.
What I found in the antique store were MUCH larger than shooters, too big to be useful for that. Colored glass spheres. Wish I knew what they were intended for.
Played LOTS of games of marbles at recess time with a chalk ring on the sidewalk of the elementary school in the '50s! I wasn't too bad, if I say so myself...
Not shooters but targets to be shot at. The big ones about 3/4” were called cobs. The really big ones were known as king cobs and about an inch in diameter. If bigger than that, I don’t have a clue to the purpose.
And yes, I too got down in the dirt and played marbles. Did you play for keeps?
Yes, if someone called "keepsies", others could participate or not.
We never used cobs. It would be interesting to read about the schoolyard marble game variations in different areas and different times.
Speaking of marbles, did you ever fry marbles? Was all the rage in the 50s or 60s.
Could use any marbles that were at least partially clear but the transparent colored or clear marbles gave the best effect.
Heat on the stove in a frying pan (no oil!). Drop one at a time into ice water. The inside fractured and made beautiful sparkling jewels. (never had one shatter)
Seemed to work better the hotter the pan and the colder the water. Also, I think it worked better dropping them one at a time instead of dumping a bunch at once.
People would glue them into jewelry fixings and make necklaces, earrings, bracelets, give to sisters and friends. Some sold all they could make. I fried them for fun.
I wish I'd kept one. Sir Google showed me photos.
