Huh?Woah. The motor turns the other direction. Kewl.
A majority of currently built dust collectors rotate clockwise facing the intake. Yours rotates counter clockwise. In itself, makes no difference in performance. More important in yours is the amount of high off center position of the impeller. This results in a higher static pressure as the air moves through the tighter gap at the top then expands towards the bigger gap at the discharge. This blower will move more air than similar designs with a more centered impeller. It should work quite nicely for whoever gets it.Huh?
Ah interesting! It definitely does pull pretty hard compared to the other jet dust collectors I haveA majority of currently built dust collectors rotate clockwise facing the intake. Yours rotates counter clockwise. In itself, makes no difference in performance. More important in yours is the amount of high off center position of the impeller. This results in a higher static pressure as the air moves through the tighter gap at the top then expands towards the bigger gap at the discharge. This blower will move more air than similar designs with a more centered impeller. It should work quite nicely for whoever gets it.
What he said. I sadly would find a home for it, as my CNC mill arrives next week, but I'm in AZ and it's too far away to make it financially responsible.Ah interesting! It definitely does pull pretty hard compared to the other jet dust collectors I have
