- Joined
- Jan 27, 2005
- Messages
- 13,109
- Likes
- 5,585
- Location
- Dalworthington Gardens, TX
- Website
- pbase.com
The turning challenge for the month of July 2023 is to turn an emerging bowl. If you are not familiar with emerging bowls, you can Google "emerging bowl woodturning". Here are examples of a couple of emerging bowls in the forum gallery posted by Dick Koch, a member of my club, the Woodturners of North Texas.
And, here is a video by Mike Peace showing one way to make an emerging bowl. There's more than one wayto skin a cat to accomplish this task and you will be able to find several other Youtube videos.
View: https://www.youtube.com/watch?v=VOvxjxhnaXI
For the purposes of this challenge, an emerging bowl shall be turned on two orthogonal axes (90°) from a solid block of wood that will be cut in half on a bandsaw (or two blocks joined with a paper glue joint, hot-melt glue joint, or other suitable temporary means of holding). The final emerging bowl shall be one continuous piece of wood without any glued-together parts. This means no winged bowls and no not something that looks like an unfinished roughed-out bowl. You must use either traditional handheld turning tools (gouges, chisels, and scrapers) and/or carbide-tipped handheld turning tools. You may not use any kind of rotary cutter or sphere-turning jig.
And finally, the fine print from the official AAW Forum legal consultants -- Dewey, Cheatum, and Howe:
- Only one entry per person and one main photo of your emerging bowl. A departure from the past -- you may also include one close-up detail photo.
- Entries must be posted in this thread.
- The deadline for posting entries is midnight Coordinated Universal Time (UTC) on July 26, 2023.
- As always, this is a turning contest, not a "moldy oldie" photo contest, so in fairness to everybody, make sure your work is something you have made since this challenge was issued on July 3, 2023.
- You may not post any photos of your entry in this month’s challenge in any other thread or in the gallery until the voting has ended and a winner has been declared.
- Voting will take place from July 27, 2023, through midnight UTC on July 31, 2023.
- Solicitation of votes will result in disqualification.
- The winner might have to pass a lie detector test before collecting the prizes.
Good luck, have fun, make shavings, and let the chips fall where they may!!
