Milliput opinions
Orange, CA
Milliput is an epoxy that handles like wood putty, comes in various colors. Mix equal parts of the two putties for 5 minutes, then stuff into cracks. You can sand, drill, screw into it. I saw it at our woodturner club, searched some threads on this site, and bought on Amazon. Used it on two pieces—jarrah burl and olive. I’m not impressed but will keep trying. It kept falling out, especially when I jam chucked the piece and applied a bit of tailstock pressure.
I’m wondering if others have advice and experience with this product. So far, I think the two part liquid 5 minutes epoxy works better and one can easily add color or sawdust to it.
I have used black Milliput to fill worn holes, cracks and voids of a variety of sizes with excellent results. I leave it at least 12 hours to cure and then it cuts really well with a gouge and is easy to sand. It ends up with a matte finish when sanded to 400, and I have not tried to polish it.
An example in lightly spalted silver maple after sanding but before finish.
An interesting product that I havent come across
I have not used the Milliput brand but I did use the common hardware store version that comes in a stick with the 2 parts surrounding each other.
Before putting the putty into the void I would rough up the fibers to give it a mechanical bond, then after it has cured turn it smooth and under cut the surface about 1/16th" deep. The surface is then refilled with powdered mineral like turquoise.
The fill process is to first spray the surrounding wood with thinned shellac to keep the CA that will be used to solidify the mineral does not soak into the wood. the next step is to support the area in as level as possible, spread the mineral, drip CA onto it and when the CA has set smooth over with rasps. This is an example of the method used to fill worm holes in mesquite burl.
Ive used all 5 colors of milliput. I find you need to wet the surface slightly that you are going to epoxy. It does not color well. I mixed Trans tint dyes. It looked great in your hand but after dry and you cut into it there is only a slight pastel of the color. I used it as a sort inlay to glue to parts together on ornaments abd it worked great. Ive also used it to fill voids and cracks. Some of these have the milliput filler
I never fill cracks. If I have something that cracks, it becomes fodder for smoking pork loins. I really don’t want to draw attention to make the crack a major design feature in a finished piece. So very few of professional turners that never come here allow cracked work to leave the shop either.
Nice to know but not the subject of this thread. There are many pros who highlight cracks—especially the Hawaiian turners like Kelly Dunn who uses pewa and fills cracks.
I don't fill cracks often. I'm a firm believer in John Jordan's quote. Life's to short to turn sh$%y wood. However sometimes you have a piece of wood you just can't let go.
Sorry, I didn’t know there was response restrictions on your post. Maybe you can mention that next time. No wait, I’ll make it simple for you and just click the ignore for you.
Alan I've been on this forum for almost 20 years and it is a normal thing that these threads migrate into something else or have outreaches that don't quite jibe with a question. Best if you can to just ignore the outriggers to your question. Pertaining or not folks are just trying in their own way to help.
Thanks Bill. I’ve been on wine forums for decades so I’m familiar with thread drift. But the OP can redirect back to the original thread and others can certainly start their own thread that might be more fruitful. If my redirect puts me on ignore because someone is thin-skinned, that’s ok but I didn’t try to hurt feelings.
