Need Powermatic Inverter Parameter Settings List
I've ordered a Delta Series 1 inverter, model number VFD015S21. I know I'll need to set parameters after I install it. A lot has been written here about programming inverters for PM lathes, but as best I can tell, a list of the parameter settings for this particular inverter hasn't been posted. Does anyone have such a list?
What model lathe and is that the same as what was on it? I think I have a list for the 3520 on my hard drive or on google somewhere.
The parameters are the same for all VFDs and have been published on this forum in the past. The Doc Green info is very helpful, too. The designation for each of those parameters will vary from brand to brand. The manual you get with the VFD will tell you how that brand refers to each one. Sticking with the Delta line means your wiring of the new VFD will be straightforward.
The above sheet was found in my search. I have no clue where/when I got it or who created it. I also found this longer pdf document that has each parameter with the factory setting and changes that I made.
Thanks! This is just what I was hoping to get.
