Got a little extra jingle in my jeans this month and forked out for a Jet 1221.This puppy packs quite a bit into a small package, am impressed! For anyone who's just gotten one, or is about to order one, here's a recommendation: break in the brushes before putting it under load. Mine had a scritchy noise when run in reverse, I called the vendor, and they mentioned that being a common concern, and that it was the brushes. Then I remembered: the Nova Comet II manual directs users to run the motor at a fairly high speed for 30-40 minutes before putting the lathe under load. I did this with the Jet 1221 today, at various speeds 2000-3500 rpm, and the noise went away.
I'll still use the old Jet 1236 for much of my bowl turning, especially wet out-of-balance stock, but the 1221 handles much heftier stock than expected, can turn really s-l-o-w, and holds its speed well. Darned things weighs 50# more than the last spindle lathe -- good for a bit of bowl turning, not so much for taking to club workshops.
Instant reverse is pretty slick too.
