Oneway 1640?
N.C.
Hi,
This is my first post. I have enjoyed turning for close to 30 years. Being a high school shop teacher I've always had a couple old rockwell lathes to use in my school shop. They are fair lathes. I am building a shop behind my house and want to put the best lathe and bandsaw in it that I can afford. I have got into selling turkey calls and crow calls that I turn and hope to get into selling a few bowls in the future. Being able to set up a chuck on the inboard and outboard side of the 1640 will make it like having two lathes when making turkey calls. I use different jaws for the steps in making them. With the 1640 can I have a chuck set up on both inboard and outboard end of the headstock at the same time? All I would have to do is reverse the motor when I use the outboard side? I don't need a tail stock for making turkey calls.
Thanks,
Jack
You can indeed have a chuck mounted inboard and outboard at the same time on the Oneway 1640. Just be sure the chuck has a set screw to lock it in place so it won't unscrew when going backwards. The 1640 is a real nice machine an a pleasure to turn on.
However you can have the same inboard/outboard setup on an number of other lathes too. And if it has reverse you can run it in reverse.
For example my wife has a General 260 with and inboard and outboard. She can use the outboard with the lthe in reverse. We also have a big Oneway.
happy turning,
Jack While your looking at Oneway check out the new Versa mount quick release mounting system. It lets you change chucks and faceplates very quickly.
Oshkosh, WI
Jack,
I'd sure like to see your turkey calls. Please post more information and photos when you have the time.
Casselberry, FL
Sometimes when I'm turning outboard, I don't even use the reverse and just stand on the "regular" side of the lathe. I am also a satisfied 1640 owner.
