Pencil marks
Dorset, VT
How do you remove pencil marks from projects. Sanding off seems to take forever. Is there a better way to remove same or perhaps a better way to mark lines on the wood.
I'm with Robo, erasers work very well. Get a good eraser, not the one on the end of the pencil. Also, try not to use the hard lead pencils - they leave a faint line and make an indentation in the wood. I like the softer lead pencils that make a mark without a lot of pressure.
I use 6B pencils as the "lead" is soft, and does not leave an impression in the wood. Learned this tip from Rolly Munro during his symposium demo years ago. They do wear down fast, so I buy several each time I go to the art supply store.
DNA works great.as.well.as.a.good.pencil.eraser. however #2.pencils.dent the wood and that has to be sanded out. Use a.2B or softer.artists pencil. They dont dent the wood and DNA takes it off very easily.
I'm with Rick - 6b or 4b either are nice and soft, don't leave an inprint and come off easily with dna or, better yet, a mars white eraser. I keep a bunch of clutch pencils around the shop loaded with 6b and 4b lead in 3mm and 5mm diameters - like the sketching or tool box pencil kits available at Craft Supply.
Marc I had the same issue,. erasers sometimes work, other times, not. DNA and Acetone were also hit and miss. But a month ago I discovered using isopropocol alcohol. It works great. I cleaned a piece of maple yesterday as well as used it to clean my erasers. it's cheap. get it at the drugstore.
Pencil on wood reminds me of Mr. Kendricks our high school wood shop teacher. We had required projects to complete before moving onto something we really wanted to make. He liked to keep the whole class at the same stage of the required projects. So if you were a fast worker when you showed him your work he would scribble all over it with his pencil telling you to sand the marks off before moving on to the next step. He was an awful teacher.
Thanks I’ll try the 6b , seems like I’ve spent hours trying to remove from ash wood
