- Joined
- Apr 27, 2004
- Messages
- 9,176
- Likes
- 5,795
- Location
- Lakeland, Florida
- Website
- www.hockenberywoodturning.com
This is the most effective finishing cut I have found for interrupted surfaces such as outside of natural edge bowls or multi center spindles. It is a cut that is easily mastered on spindles but requires a basic level of tool control to be used successfully on bowls. if you are trying to learn it, my suggestion would be to practice on spindles and then practice off center spindles.
I posted a video on YouTube that I cobbled together from a couple of demonstrations and some clips from turning a natural edge bowl.
The video gives an overview of what the pull cut is. It is along way from being an instructional video.
I hope other turners that use this cut will offer additional comments on how to do it effectively.
You tube link
http://youtu.be/OwLnJVLqerM
The cut is done with the wing being "pulled" ( or pushed ) over the wood in the direction of the handle. The nose of the gouge is always out of the wood, trailing the cut( it is the nose that is being "pulled" behind the cut). If the nose contacts the wood a catch is likely. The tool is held with the wing at about a 45 degree angle to the wood rotation flute at 12 o'clock. The tool is rolled left or right until the cutting edge of the wing contacts the surface and begins to cut and peel the wood away much like peeling an apple with a knife.
This cut produces a very clean surface and the tool handle can be dropped to make a cleaner cut with a steeper angle of the wing to the wood. I use this cut on problems woods that are not cutting cleanly with the push cuts. I also use this cut on the outside of natural edge bowls and it produces a clean cut on the bark most of the time. Using it on a the interrupted surface requires a light touch. ( variations of this cut include a roughing cut with the bevel not riding and one with the tool parallel to the floor on the tool rest).
The wing of the gouge must be properly sharpened with a radius curve like the Ellsworth grind or almost flat. Any dip and it will be difficult or impossible to use in the pull cut. I use this cut on interrupted surfaces, platter faces, and problem woods where I'm getting some tear out with push cuts. The video is not a teaching video but the demo clips give some basics on how to do the cut.
You tube link
