Replacement remote for JDS Cyclone dust collector power box
Eastern Washington
I have a JDS cyclone power box for my 3hp dust collector. Its only a year old, bought brand new (old stock). The remote had an 'accident' and now I'm in need of a new one. It looks exactly like the one from Jet, the only difference is the JDS and Jet sticker (both on the control box and the remote). Does anyone know if Jet's will work? Or does anyone have a JDS remote they're no longer using. Pictures below are of Jet's product. Wondering if I need to worry about frequency or other compatibility issues.
I called Jet, the tech I spoke with said he didn't know if it would work despite the two units looking exactly the same except for the label. His suggestion was to buy a brand new cyclone dust collector. Not going to do that.
It's called a remote relay switch. Unfortunately, many of them are coded (perhaps not as severely as car key remotes...) There will typically be some switches in the relay (which you still have) and switches in the remote (that got accidentally "lost."). Those switches and the frequency should match.
I wonder if either Jet or JDS would sell you the remote and allow you to return if it doesn't work.
Another alternative: An electrician can install a new remote relay switch for you. The remote relay switches themselves are inexpensive; the relay motor starter is the more expensive component (and the electrician's labor will be the most expensive...).
Best of luck!
