- Joined
- Dec 22, 2006
- Messages
- 7,117
- Likes
- 9,858
What woods used in bowls are best finished with buffing only the woods natural oils. This would avoid the never drys problem with the application of the usual oil based finishes.
Took this quote from the other thread, and am soliciting comments on this.
I've been using Watco Danish oil natural finish since very early in my lathe experience back in the 1980's. To this date I have never experienced an example of "never dries problem". If cwearing can respond, that would be great, but anyone who has experienced this, let me know your findings, if you would please.
There have been times when I have experienced this with Danish oil, and it has seeped to the surface over a period of a few days, but never longer than that. I've had some of my bowls for years, and have never noticed this problem. Is it possible this problem could exist with over-application, or repeated saturation of the wood with the Danish oil?
My procedure is to apply the Danish oil to completely cover the surface, and to wipe dry with a cloth or paper towel within a few minutes of the application. My intent is to preserve the natural coloring of the wood as much as possible by using this method of a light application. I almost never apply a second coat. As I said, sometimes a little seepage does occur within a day or two, and it's easily taken care of by wiping again with the cloth or paper towel, or it simply buffs out. My bowls usually set in the shop for at least a week before I will Beale buff.......
ko
