Segmented Objects
Rochester, NY
I am turning a segmented piece - actually a hollow sphere - of curly maple and padauk. How do I keep the padauk dust from not discoloring the maple. When I finished turning the sphere, the maple was white. After sanding it has an orange tinge.
Thanks for the replies.
Howdy Charlie,
This is why I dislike turning Padauk... that orange dust is ferocious and sticks to everything. I kinda swore it off in my shop and go with other woods to get the reds and maroon type colors. There is nothing you can do to stop Padauk from turning brown either... you can slow it down with UV resistant finish and hiding it in the shadows. But it's gonna happen.
As for your question, your last cuts on the lathe should be a clean as you can possibly get them. A clean cut will take that dust away from the surface and not contaminate your Maple. The next step is to apply a finish to seal all the pores in the Maple as best you can. A sanding sealer, shellac, or perhaps a water-based finish that contains a UV inhibitor might be a good choice. Something that will dry well and not be soft. While an oil might pop that Curly Maple for you, it may take a while to cure because of oils within the Padauk... maybe weeks depending on the product. An oil with a slow drying time might also carry the red color dust and reddish oils across to the maple in a "bleed" type scenario. I would absolutely stay away from anything with wax.
Once you have the wood sealed and dry, try your sanding targeting by hand where you need it. Be super meticulous with controlling that dust. Re-seal the Curly Maple as needed to keep it clean. Then if you need, do another sealing coat on everything if you need to go with an oil or wax on the final finish so that surface bleed can not happen and ruin your efforts.
Best of luck! I hope you are able to get the results you were looking for!
Apply sanding sealer. Sand with the first grit. Blow off the sanding dust. Apply another coat if sealer. Blow off the dust. Apply another coat of sealer. Blow it off. Repeat for each grit. The sealer helps fill in the pores that capture the dust so it blows out easier. Padauk and maple are the worst about this.
Thank you for the replies. I turned the sphere again with sharp tools and then applied sanding sealer. Then sanded and applied finish. The color is better, but not perfect. Will try multiple coats of sanding sealer the next time.
