  • Sign up for the 2025 AAW Forum Holiday Swap by Monday, November 24th (click here for details)
  • Congratulations to Tracey Lee for "Huggins with Rope" being selected as Turning of the Week for November 10, 2025 (click here for details)
Sharpening anxiety
Well, my CBN wheel came in. It will be my only CBN at least for the near future. I’ll be installing it on Saturday. Quick question, and I know that it is probably a “see how it feels” thing, I am right handed. Should I mount it on the left side or the right side? Any advice?
I'm right-handed and see no difference in use of wheels mounted on the left or right.
If you mount it and it doesn't turn perfectly true, get a spherical washer set if it didn't come with one. I bought some from Woodturner's Wonders. Inexpensive. Sometimes the nut on the grinder is not perfect and the washer set takes care of that.
I ordered a set of the washers when I ordered the wheel. I figured better to have them. And use them regardless of needing them or not. I’ll mount it on the left side, if it doesn’t feel right, I’ll swap it. Thanks.
I saw Ashley Harwood demo some years back, and she would only sharpen on the left side. I found that funny/strange. With turning, all actions are done with the body. I do tend towards being ambidextrous though so maybe easier for me than for others. I do like to keep my Big Ugly tool on my right side with my left hand by the tool rest. I did try it the other way and found I was not as comfortable with it. I guess it just depends.
I have found my Tormek useful again since I started stropping my skews. I have some pieces of plywood with stropping material on them, some pieces of poplar, alder, and some kangaroo leather which compresses less than most other leathers. I did see one from Bernal Cutlery in San Francisco that is cork with green chromium oxide on it. I really like it for my kitchen knives. Strangest stropping material I ever heard of was balsa wood. After thinking about that, I think it might be ideal for carving chisels since you could make it conform to any shape. One guy on You Tube, I Sharpen, swears by kangaroo tail with no compound. To demo how sharp his knives are, he slices cigarette papers. I was impressed!
One hint I heard that may be useful:
Since the motions used for sharpening and turning can be similar, it's best to mount the sharpening wheels at about the same height as the lathe spindle. Far less awkward than if too high or too low.
Leather on wood: the advice I got for chip carving knives (the sharpest knives I have!) was use leather as thin and hard as possible. Thick, soft leather can tend to compress and round the edge a tiny bit..
Probably a good starting point.
Before jigs I sharpened the Ellsworth grind by hand with a platform for support.
I found mounting the wheel at about shoulder height gave me the best view and results.
When I switched to jigs I found something a little lower than lathe height to be most comfortable.
I started turning exactly 5 years ago yesterday during the pandemic shutdown, with not a clue how to sharpen my tools. After many YouTube videos and a lot of wasted steel, I slowly began developing my sharpening skills, which improved exponentially with the Wolverine jig and CBN wheels. To me, it's a circular thing: turning is sharpening is turning. After I moved my grinder to the workbench directly in front of my lathe, I got in the habit of just turning around for a quick touch-up on the 180 grit wheel, then right back at it. Another epiphany for me was the long learning journey of learning to grind the way I cut, which made ALL the difference. I started to develop that skill after a couple of classes with Matt Monaco, who uses some very idiosyncratic grinds like a wizard at the lathe. I will be taking his platter class at John C Campbell next month, and no doubt will learn much more. The learning never ends!
It's not psychological. If your wheel is CBN, it is much easier to use, smoother and more predictable than the AO wheels. Enjoy!
Agree that carbide tools are not an answer - they work differently (even the cupped cutters) and inhibit learning how to use hss tools.
Sorry, just saw this. With students, I haven't experienced the use of Hunter tools inhibiting learning to use conventional gouges. I teach both, they learn both.
I have no idea about those learning on their own.
I was one of the last holdouts to switch from conventional grinding wheels to CBN. What I don't miss about the conventional wheels is the requirement to add balancers to some wheels, the constant, although slow, decrease in diameter, plus the constant need to dress the wheels. I used a single-point diamond tool to flatten the wheel, then a multi-diamond tool to smooth the wheel. All this made a lot of dust and mess. Looking back, what a pain.
Can't remember, it may have been John Lucas who finally convinced me. After the first CBN I couldn't go back. I went through a number of grit combinations before settling on what works best for me.
Speaking of grinding wheels, anyone "need" one of those large antique grindstones? My dad sharpened his axe on it, turned the stone with a crank handle.. I have just the stone plus the iron arbor. I never had the frame. I'm downsizing. Trade for a good story or a good joke.
Speaking of grinding jigs - I see nearly everyone uses the Oneway Wolverine system.
I got hold of a Savannah Pro-Grind Sharpening System (simply because it was cheaper than the other ones at the time) and have been quite happy with it. I love that it came with setup blocks, making it really easy to repeat the same angles accurately.
Anyone else use the Savannah one?
I have one called Peachtree. It looks to be the same as your Savannah. I'm not sure how different the Wolverine is, but it doesn't seem much different in the videos I've watched.
Not to change the subject, I ordered a one inch skew chisel from penn state. Any opinions?
They are my favorite “hi value” tool source, ie a lot of value for the $. No fancy handles/wood or ferrules, good m2 steel that works well. I have a couple of skews and a bunch of scrapers. BG flutes are short, limiting tool life, but good for trying out new grinds etc.
I have mostly Sorby chisels and just recently bought a CBN wheel that has made a big difference in my grinding. I figure I can practice on an inexpensive one inch skew, plus I’ve been wanting a one inch skew due to the fact that my half inch skew doesn’t seem quite big enough.
I have a few of those inexpensive 1-inch skews with different grinds on them: Sorby, Hurricane, Benjamin's Best-they all seem about the same. They work just as well as the big-name brands, and you're not so reluctant to grind away steel chasing the optimal grinds and radii.
I still use PSI tools, they are good. When I started I bought a set if 8 from them. The bowl gouges are long gone, but the skew and parting tool still get use. They are m2 steel made in China last I knew. Basically a knock off of Robert Sorby.
JKJ,
I also have one of those antique grindstones. When we bought our lake property in Michigan I unearthed it from the pile of detritus where the old farm shop had burnt down. I hauled it back here to Delaware intending to rebuild a frame and treadle for it but never did accomplish that… maybe I’ll have time when I retire from my retirement!
I haven't tried any of the Rockler, but from my experience flat-topped carbide tools in general, although they don't need sharpening and are easy to use, sometimes may not cut cleanly on certain wood and in certain circumstances. At least not for me. The Hunter bits work more like very sharp gouges. With reasonably good wood and reasonable tool control the results can be pleasing. As an example, I sized this piece from African Blackwood with a parting tool, then turned with a Hunter Hercules tool with the tiny #1 cutter, used like a spindle gouge in this case. This is off the tool with no sanding. With some care the polished cutter can leave an ALMOST flawless surface. (I turn at high speed which helps.) After rough cutting to near the desired shape, the long section is mostly a single cleanup pass with a couple of careful restarts. You can see where the surface still needs some work. (Sorry, the wide angle camera lens distorts a lot!) View attachment 76966 This is the same piece after sanding by hand with 600-1200 grit. (I still wasn't happy with the ends so I reshaped them after this, again with the Hunter tool, and resanded.) View attachment 76967 I held this piece with what I call "jam centers", kind of like jam chucks but acting as centers with jam pieces turned to fit the little curved bowls I'd cut in both ends. Before shaping the jam pieces to fit, I had cut short #2 morse tapers on both so I could hold them in the headstock and in the 2MT built into the Nova live center. (My favorite live center - extremely adaptable to hold almost any small thing!) BTW, I make "jam" and friction centers as needed to hold the ends of spindles and other work, for example to support an end a drilled hole such as when making a conductor's baton. With the 2MT in the Nova live center it's easy to make one of any size and shape as needed. A few in the foreground here, with some things that come with the Nova center behind. This works after a fashion with Oneway live enters if you knock out the point - held, I think, with a #0MT. View attachment 76978 The point is, for me, the Hunter carbide tools can do a reasonable job. The same thing could be done with a 3/8" spindle gouge but might require resharpening since the African Blackwood is so hard. I wouldn't try this with flat-top scraping tools but someone else might. I rely on the combination of the Hunter Hercules and a spindle gouge for lots of other things, for example to acrylic things such as this little stopper. BTW, for small things I loves me some new Nova dome jaws! I first saw these at the TAW symposium the end of January. View attachment 76970 JKJ
I too love the Nova live center. with it's built in MT2 there are lots of things you can do with it. I ordered a block of High-density polyethylene (HDPE) and have made numerous cup chucks for making spheres and other small items.
