Sharpening Wheels
Have you seen these wheels before?
  • Yes.
    Votes: 0 0.0%
  • No.
    Votes: 4 100.0%
  • Total voters
    4
Emiliano Achaval
Maui, Hawaii
hawaiiankoaturner.com
On my recent trip to Argentina I had the chance to demonstrate at 2 different locations. I showed them all about the 40/40 grind. On the first place there was a new Vicmarc VL 300, but a $25 Chinese bench grinder with a $2.00 wheel. The second place had a beautifully restored, well over 70 years old lathe. Looked to me a lot like an Oliver headstock and tailstock with a newer bed. There, I sharpened on a decent bench grinder that had expandable rubber wheels with made for steel grinding belts. I was surprised by the quality of this wheels. Since I have been thinking of upgrading the wheels that came with my second bench grinder, a Delta 8 in variable speed from Lowes, I decided to look into these wheels. My host contacted the distributor. Each wheel was $22 US and each belt was only $2.50 US I purchased several 120 grit, 150 and 60. They are only 6 in, but way better than what they give you with the Delta. I was wondering if anybody has seen these wheels in the woodturning world. A quick Google search and I found some very similar... I left the 60 grit on, have to sharpen a blank , it's very easy to change the belts... I will report in a few weeks, can't see or think anything negative about them , other than the 6 in diameter, but they are wide....
Those type wheels seem more common in lapidary and jewelry making. In my experience, they're okay for rough grinding. They might work well for free form sculpture work in wood.
Google on "rubber expanding drum". Rio Grande has a few different sizes (quite a bit more than $22 though).
