Sharpening with Wolverine jig
Mosinee, WI
I just recently purchased a CBN wheel and wolverine sharpening jig for my tools. I was getting a lot of snags after sharpening my gouges. I consulted with a season turning veteran and my wings were not straight but rounded. What am I doing wrong and is there a way to set up the wolverine properly?
Sharpening on the Wolverine jig takes a little time to manage your gouge wings properly.
I suspect you are using a little too much pressure, but with a little practice, you can solve this issue very easily.
In my opinion, it's not about getting instruction from others, but to just get more time doing it! :)
=o=
The jig sets your angles but you govern the shape of the tip and wings by the amount of time and pressure you use on the various parts of the profile. The flute shape has an influence as well. It's easy to get a "birdsmouth" with a little hook between nose and wings when grinding a v-shaped gouge with a quick transition from the bottom radius to the straight sides of the flute.
Get with your seasoned veteran and look carefully from the side at his gouge's profile. Then turn over your gouge, resting the top of the flutes against the grinder platform and shape it symmetrically to the same profile. Put it in the Wolverine jig at the recommended settings and grind back to the new profile until you have a sharp edge. Try it out and see if it works for you. Remember, "Practice makes permanent" so develop a method that works for you and be consistent.
I usually use an "Ellsworth" grind with swept back, slightly convex wings because it is a versatile shape, but many shapes will work as long as there is a smooth curve with no concave sections. If you are in a club ask other members if you can try out their gouges to see what you prefer.
Here's Doug Thompson shaping a gouge, although he does it freehand, at about 14:00. Thompson
The jig setup is just part of the equation. Even with everything set up just right, over time you can change the profile by grinding too much (or not enough) in places, and end up with a sharp gouge that's catchy. I think a slight convex "hump" is OK, but if you have tall rounded wings, you need to grind more on the sides. If you have a concave dip in the wings that creates a pointy beak of a point, you need to lighten up on the sides and grind more off the point.
=o=
Thank you for the advice. I got several old gouges that I've been practicing on so I don't grind away my new, good ones. I go to my friend to get the good ones sharpened until I learn how to do it.
Central Wisconsin Woodturners are not to far away in Wisconsin Rapids. I'm sure someone there would be willing to help if you asked. Sometimes another set of eyes sees things we miss.
It's very difficult to know what you are doing "wrong" without seeing what you are doing. The wolverine is versatile but there are some things I think are better done in ways they don't describe.
When I first started turning I paid a guy at Woodcraft to sharpen my gouges at $6 each (not $60 - typo!) After a short time I realized I could do a better job.
I agree strongly - get someone with experience to give some help - all respectable woodturners are willing to spend time teaching sharpening. I've had many people come to my shop just for sharpening instruction. I have them bring all their tools so I can judge there level of sharpening experience and decide what to do differently. I should have taken before and after pictures of some. It was amazing that some were able to turn anything.
I first show them how I would sharpen that tool then let them sharpen, with me watching and gently advising. "NO, don't ever do THAT!"
With the Wolverine, I sharpen almost all tools free-hand with the platform: skews, NRS, spindle roughing gouges, parting tools, my special wiicked point tool, more. I use only CBN wheels on that grinder - an 80 grit for shaping tools and a 600 grit for sharpening.
I far prefer the "mini" platform over the big one that comes with the wolverine, especially with older tools that have been shortened by sharpening for years.
I use their gouge jig only for bowl gouges.
I NEVER use the long arm attachment. With improper use it's just begging trouble. I also never use the skew attachment for the long arm. There is no need.
I make plastic angle templates for my favorite tools. I made this one to set the platform specifically to sharpen hand scrapers.
I make others as needed for skews, NRS, etc. (In this photo I've not yet painted the backs white for visibility.)
Hello Richard, a few weeks late, but...
Rounded wings- I'll use the side wing edges of any gouge as long as the edge is straight to lightly convex in shape, but never concave at the edge. But concave can happen, especially coming off the nose around to the wing edge. That can be problematic.
I just wanted to verify/clarify the "rounded" part of your request. I hope you've gained a resolution!
Here is my sharpening problems video. Should help.
View: https://www.youtube.com/watch?v=_b73Br6xFc4
Hello John, in your video:
View: https://www.youtube.com/watch?v=GXetyA6-0b4
, at 5:02 you show a setting jig for the angle. Let's say you have a gouge that needs to be redone or has no edge. How do you determine the correct angle of the tool so you can make the jigs? (I have some gouges that I want to set the proper angle and make jigs for repeatability.) Thank you.
@Manny Yabar I do the same as @John K Jordan , ie use ~0.08” thick plastic to make angle setters. You will need an angle gauge. For gouges I like this one:
Trial and error - Grab a tool and initially guess (possibly use another tool measured with the protractor to help ) the platform angle. Grind enough of the edge to measure, then just keep adjusting the platform until you get the desired angle. How close you get to the desired angle depends on how OCD you are (for some +\- 5, me ~+\- 1, I am making a measuring device). What is important is that it returns the platform to the same angle each time.
Photo of a couple of mine. I’ll cut a bit of the corner of with a saw, then just feed it into the grinding wheel. Remove the side flashing with a razor knife. I then use a drill mounted burr to remove the center of the arc, leaving a pad at each end of the arc. I then use an engraver to label the angle and go over that with a sharpie (the sharpie ink will wear off over time).
I bought a cheap General angle gauge at Lowes. That let's me accurately measure the nose angle. However the exact angle does not matter. Anywhere from about 40 degrees to 60 works. You determine the correct angle for you by what shapes you turn. Deep narrow bowls need an angle like 55 or 60. Wide shallow bowls a 40 degree works. The more acute angles cut cleaner but on many of the bowls I do I simply cant ride tge bevel through the whole curve.
The original question lacked specifics. Some thoughts:
1. The tool types weren't specified. All but the swept-back bowl gouge are best ground using a tilting-platform jig.
2. If you're using a swept-back bowl gouge, you probably have a lathe which doesn't have an outboard facility.
3. Most sharpening advice since 1957 promotes sharpening/bevel angles which are 15 to 20 degrees larger than optimum.
4. Sharpening is very quick and simple once you understand it. Much of the advice generously given is suboptimal.
5. I suggest Richard that some serious research would go a long way to solving your sharpening problems.
Best wishes, Mike Darlow
View attachment 85897 View attachment 85900
Hello, what brand /specs is the cbn wheel on your grinder, I am looking for one.. yours look very well made
thanks
Doug when you contact the plastic to the grinding wheel does it clog the grit?
thanks
I've had a pile of CBN wheels of different grits. After experimenting and using all of them I've narrowed my wheels down to three. They do everything I need for the lathe. I buy all wheels from Ken Rizza at Woodturners Wonders.
The one in the photo in message #9 is an 8" wheel, 600 grit CBN, wide, square corners, 1" of grit down the size. I think Ken calls them "Mega-square". My most used wheel. I use it to sharpen all skews, bowl gouges, NRS and other scrapers, parting tools, my Wicked Point tool, hand scrapers, and others.
BTW, unless you have a special need, don't bother with the CBN wheels with radiused "corners". The radius reduces the useful width of the wheel, and eliminates the ability to grind and sharpen inside corners on certain custom-made tools. I bought one to try and gave it to a kids turning program.
I also have an identical wheel, except 60 grit CBN. I use it for shaping tools that requiring a significant removal of metal. I used to shape with an 80 grit wheel but the 60 is quicker.
A slow speed Tormek has a similar but 10" wheel with 1200 grit CBN. I use it almost exclusively to sharpen my spindle gouges. Sharpening at 1200 grit can be slow but it gives a great edge on the spindle gouges. (I'm real particular about them!)
Note that after sharpening skews, bowl gouges, NRS, and spindle gouges, I use the leather stropping wheel on the Tormek to remove any grinding burr. I also remove the grinding burr on scrapers and NRS then burnish a burr with an Arno burnish, IMO the best in the world!
For hand scrapers, I grind on the 600 grit with the platform at 90 degrees, use a red extra-fine diamond hone to remove any grinding burr, then add a burnished burr with the Arno. For me, the hand scrapers are the key to smoothing bowls and platters and such and eliminate much sanding. I do NO power sanding with rotating disk. After the hand scraping, that would be a step backwards.
There, as usual, I wrote too much. I can't stop myself.
If I may be so bold to answer that, no, the plastic doesn't clog the grit, at least not the way I make them. I first set the grind a tool to the desired angle on the Wolverine platform then make a gauge to match.
Mark the curvature of the gauge on the plastic by holding on the rest and against the side of the wheel. Cut the radius on the plastic on the bandsaw then cut a relief in the middle since the gauge doesn't need to contact the middle. Then first hold the I gauge against the 80 grit wheel to refine the radius and against the 600 grit wheel to smooth it.. After that, setting the platform to precisely the right angle is a 5-second process. Haven't had any plastic clog the grit, but I don't press very hard. If it DID clog, sharping a scraper or two should clean up the wheel.
Here's one I use for my curved negative rake scrapers. (spray painting the back of the plastic makes the gauges easier to read.
Here are some others before adding the white paint. (Also shown in msg #9) All of mine have the paint now.
The bottom one has two different angles, one on each end. BTW, the 60-deg skew is the first tool I put in a beginner's hand. (60=deg is far more "forgiving" and makes the skew easier to learn, building confidence quickly. Doesn't necessarily cut as cleanly and as effortlessly as a skew with a smaller included angle but that doesn't matter for the first lathe lesson.)
Can't remember when I started making these but it's been a while. SO useful. Note that some pro woodturers who do the circuit and symposiums sell similar angle-setting gauges- one I saw had four angles on one square gauge. These are so quick to make I never felt the need to pay someone to do it. Besides, they don't always have the exact angles I want.
I was surprised by John Jordan's recommendation of a 60 degree sharpening angle for skew chisels used by beginners. I was taught to use a 25 degree sharpening angle, and teach others the same way. Sure it takes a beginner on average about 8 hours of supervision to achieve basic competence in spindle turning. The main lesson is learning to axially thrust just hard enough. The beginners' problem is a reluctance to thrust hard enough for fear of a catch, but thrust too hard and the tool nose rises safely. I'm not saying that starting with 60 degrees is an inferior way to learn, but unfortunately the use of coarse sharpening angles is widely promoted.
Mike Darlow
To be clear, I start with sharp radiused 60 deg skew primarily to instill confidence - since it is so easy. This is ONLY for the first part of the lesson.
I've developed my own way of teaching which so far, has always worked. For one thing, we don't start with the roughing gouge and a square blank - I always round the blank before they step up to the lathe so they will have a clean, perfect slate to start from.
The first task, usually takes about 5 minutes, is learning to present the edge and make perfect shavings with me turning the lathe by hand. Then we continue those shavings with horizontal skew motion. (moving with the legs, of course - I'm a relentless taskmaster) I may stop, take over, and smooth the cylinder surface if needed - I don't want them to have to deal with an irregular surface at this point. Then I turn the lathe on at it's lowest possible speed, they plane more, I inch the speed up. Constantly watching, correcting. Before long they are making perfect smooth cuts at high speed. NEVER a catch.
After a bit of learning to make planing cuts with the "easy" skew, we switch to a different skew - wider, smaller included angle, not yet close to 25-deg, still slightly radiused. When confident with that, we switch to an even smaller included angle. By that time they have a good "handle" on the skew. Then on to shallow and deep v-grooves. Then put the skew away and start on coves with the spindle gouge - more difficult to a beginner than planing with the skew due to the three coordinated movements needed. Then back to the skew for peeling and more practice and then more spindle gouge - different sizes this time. Only THEN do I introduce the roughing gouge. If time, I may even introduce a Hunter Hercules tool. It's amazing how fast some people catch on to all of this.
I've done this with dozens of students and not one has ever gotten a catch. (Knock on bubinga) I've had plenty of experienced turners and long-time instructors tell me I couldn't start students the way I do. They would be incorrect.
It IS easier with one student at a time but I've had several pairs at once - just kept me busier!
One thing I think helps a lot - I made a huge model spindle with a deep v-groove on one end and a wooden model of a skew from a piece of 1x3 board. Put them on a mini on the workbench I use these first to make it easy for them to see the angles involved and easy for me to explain what to do and what to NEVER do! Get the picture first firmly in the mind, then go the the real lathe with actual skew.
Usually someone who has never even seen a lathe before can make something to take home after an hour or so of lesson and practice.
These two friends, first time seeing a lathe, did spindles in the morning. In the afternoon a simple practice bowl and a take-home bowl, all smoothed and finished with oil. I always try to have them make something to take home.
It's gratifying to know some later got their own lathe and turn often. If they ask, I give them all the dry wood they can use!
A bin of some student first-lesson practice pieces. I direct and suggest but they turn what they want. If they have a lathe at home I send practice wood with them.
I've also had several old-timer remedial skew students - turners who got one catch years ago and never touched the skew again. Until they came to my shop. Some benefit from part instructor, part psychologist.
It can if you push too hard, but a light touch with a dressing tool clears it. I still use stone wheels. For cbn perhaps a touch with a brass brush or sharpen a scraper cleans it? Those with cbn will have to comment.
Dont use any soft metal to try abd clean cbn wheels. It can clog them.
I recently bought a "Right Angle" adjustable platform for my Wolverine sharpening system and am very happy with it. Not sure if I am allowed to post a link, but it is easy to search for. It has 28 fixed angle settings for different degrees. I mark the hole number on each tool to easily set the platform. Admittedly it is a bit pricey, for me the ease of use was worth it. I find I am more likely to sharpen often when it is easier quickly set the platform to the correct angle and of course a sharp tool is safer and results in a better cut.
This is true for any aspect of woodturning.....it is a continual quest to find solutions that are quick and easy. That is what makes both the flow and your interest level maintain a continued progress... :)
=o=
=o=
And that is why I am considering going back to "traditional" grind just using the V-arm of the wolverine and do away entirely with the varigrind (which adds complexity to the process, even if "just a few extra seconds") and see how I like the traditional grind instead - if I can quickly and consistently sharpen, I think I'll better enjoy my lathe time Vs. having to stop and fuss with setting up the varigrind, clamping gouge in it, etc. It'll have to wait til after spring cleanup and gardening is out of the way though... haven't been turning since before xmas as life has gotten in the way and I was starting to wonder if maybe I should not just sell off everything and find a different hobby (maybe I'd just go back to finding yard sale chainsaws & weed eaters, fix em up and sell em... or some part time remote jobs like BI Analyst, etc..) but I think I'll see if I can get back "into it" with just simplifying tools and grinds and projects instead...
