I made a custom draw bar for my new lathe.
I used 2 - 12mm shrink tube over the threaded rod to protect the inside of the morse taper while installing and removing the draw bar.
I used 3/8 X 16 TPI rod as that is what my drill chuck accepts.
I had to add a turned cone to center the drawbar in the 5/8 inch opening at the hand wheel area.
Yours will be custom made to your specifications.
If you use your drill chuck in your headstock (sanding, drilling etc..)you really should have one in my opinion.
Here are a couple of pics.
If you have one share a pic if you want.
