Show us your tool rack/cart
Here is mine. It's a craftsman tool box. I mounted boards around the outside in a sort of 2 step staircase. I drilled holes in the boards to fit specific tools. It holds about 70 tools. I have my hollowing bars in the drawers along with chucks, tool rests and all sorts of other stuff. I have a magnet on the wall behind the tool chest that holds some larger more cumbersome tools and my captured bar system.
awesome idea
I don't have 1/2 the tools John does ..........
with me, pegboard wall holds chucks & larger accessories, and 500w halogen backlighting
cabinet holds lathe, all turning tools used on regular basis are in plastic tubes mounted to back, with another 500w halogen light lighting front of work......
top & bottom drawers hold lathe accessories, middle 2 drawers hold turning tools not used all too frequently (hollowing, etc.)
the base of cabinet raised to accommodate my stance needed because of bad back.
do you get a lot of dust into those drawers withouth the fronts
Things have changed significantly since I first responded to this thread......
=o=
The two walls behind my VL240 in the corner of my shop:
=o=
I've switched much of my exercise program to dumbells....once in the morning, and once in the evening:
I've created several platform configurations to help with certain conditions.....sure is handy when you need it! :)
Note: Since switching to a new lathe, there is only one new platform. The rest have been adapted to a different distance between the bedways.
=o=
I just put these up. I don’t have as many tool as most of you (yet) but just put up studs and paneling on the cement wall of the shop. I’ll add more storage for chucks and other stuff soon.
Bud ... don't know how you have those frames attached to the wall, but ... I think if you can block out or shim the bottom of the frame an inch (or two or three) from the wall so the tools will lean it will be easier to use. It will eliminate the need for the cord or elastic you have which may be a PITA to use. Just my 2¢ ! 😇
Do I currently have a worthy tool storage method? Nope.
My tools in current use live in a pile under the lathe bed and
around the shop in messy wood boxes. :rolleyes:
But I am mostly posting here to bump the conversation
up to the top for a buddy. Woodturning buddies are the best!
Updated mine. Added another chuck.
It's not an issue I can stop when ever I want!
That's about $2000, or more, in chucks!
Yeah, this is an issue for you. If there is a Vicmarc VM120, or two, in that mix that need a new home, that new home is here at my shop. I'll donate the space to "store" them for you.
I own 3 chucks. The VM120 I bought with my VL300 lathe in 2001 (lathe sold 5 years ago), the Oneway Talon I bought with my Oneway 1224 two years ago, and a Talon that came with the Vicmarc VL200 I bought from a friend about 10 years ago.
A month or two ago I demonstrated it takes me a casual 3 minutes to change jaws, starting while the chuck is on the lathe, to the bench for the swap, and back onto the lathe.
I'd need at least six VM120 chucks for the jaws I have, and 4 or 5 Talon chucks for those jaws. That totals the price of a Oneway 1224 lathe! Or a seriously sweet bandsaw.
You can stop any time?? You say that as it you mean it...
I've said the same thing and really meant it. Yet I'm up to 21 chucks again, even after giving away four....
👿 But you still have three sets of unique jaws without chucks in the back of the drawer!
😇 Oh, right. But !hat's OK, I don't use those much
👿 But they are lonely. And what if you need them in a hurry some day?
🤔 Well...
