Sorby Groove Cutting Tool
Montfort, Wisconsin
Dave,
This tool is a scraper.
sharpen it with a light touch and use it off the grinder.
After a while you will need to remove metal from the long opening as the tip gets too short
Use it flat on the rest, handle level with the floor, keep the handle parallel to the ways, tool,rest set for the tool to make contact slightly above center.
Anyone have any tips on using this tool?
Hi Dave. I always cut a grove, then use epoxy.
As mentioned, use it like a scraper, very much like a box scraper. If you have a small flat box rest that will fit inside the hole the it's even easier.
If you haven't bought one yet you can make one pretty quickly (and maybe for free) from any underused flat tool, scraper, skew, etc. Grind away at the side then sharpen the cutting part exactly as you would a scraper. (you can round over the rest with a file to prevent accidental catches and wood removal!) Note that since you don't have to do beautiful finish cuts you can get away with repurposing even an old rusty carbon steel tool. (I have a box of old tools like this when I find them. just for making special-use tools.) I made one in about 10 minutes.
Pass on the Epoxy
Hi Dave. I always cut a grove, then use epoxy.JKJ
I recommend taking a pass on the epoxy. It's really unnecessary and severe overkill. If the hole in the mill body for the Crushgrind@ mechanism is drilled to proper size (1 1/2" diam), the Crushgrind@ mechanism can be pressed into the mill body using the tailstock until the locking tabs on the mechanism engage the groove in the mill body. It's a really tight fit. With this technique there is no/zero chance of the grinding mechanism working loose and coming out of the mill body. So, pass on the messy and unnecessary epoxy and go with press fit and locking mechanism tabs. - John
PS - Get a copy of Turning Salt & Pepper Shakers and Mills by Chris West. Everything you ever wanted to know on the subject. - J
