@Dennis Weiner , are you just doing this once, or do you need to make multiple cuts?
I already cut the Plexiglass rod and decided to put this handle on hold. (BTW, it was "step-cut" in three passes and yes it was clamped and secured on my table saw sled. Very slight melt).
I am creating a demo for my club on constructing cam-action handles as mentioned in prior posts. So I will be cutting and photographing. In the past, my theme has always been to use the tools that you
have(woodworking related) to create various accessories. I will probably cut aluminum tubes and round bar stock while prototyping. However, I will not be cutting Aluminum in any volume. There has been an expressed interest by club members to make their own handles other than the traditional wooden handles. Possible resulting in a club volume order of ALuminum. Of course, I will have it cut to size by the supplier!
The reason for this post was to determine if anyone knew anything about my no longer made saw blade.
@Bill Boehme resolved it for me. I was interested in getting a better cut on the aluminum and plexiglass in order to reduce deburring and sanding of the material after the cut. I am not a stranger to cutting various materials on my shop equipment, especially aluminum. I probably would not have attempted cutting Aluminum on my table saw but in my working years, I had a client that was a window and storefront manufacturer. Their factory cut aluminum on table and chop saws all day long. I gained confidence that it was a normal thing to do with the proper equipment and safety protocols. Over the years, I have made many woodturning accessories for one reason or the other comfortably. When the pandemic hit and we were all stuck in the house, I put together a presentation for a zoom demo for one of the clubs of which I am a member.
View: https://www.youtube.com/watch?v=3lb4CuD_imk
It is fairly long, but you can fast forward it. Some of the projects displayed were a Laser Story Boarding system, use of crotch center, drilling steel on a wood lathe, a batty style arch-shaped aluminum platform fabricated with a router, and a sharpening system out of aluminum extrusions for the Tradesman Grinder.
