- Joined
- Dec 22, 2006
- Messages
- 7,123
- Likes
- 9,889
It's my opinion that, for bowl turning, the tool rest height for scrapers is less forgiving than that of gouges. Basically, this is because the gouge needs to have a rubbing bevel, and since the bevel angle can vary to a great degree, the tool rest height can vary considerably according to the physical stature of the turner.
Since I'm 5'9", and generally keep my scrapers fairly level, my findings are based on that, but shorter or taller turners may have to adjust accordingly........regardless, the scraper's cutting edge should always point directly toward the center of the turning.
It's my opinion that the cleanest cut is when the scraper's cutting edge is at the centerline of the turning. This holds true, whether the scraper is used in a traditional fashion, or is tilted for a shear scraping mode. Either way, the best quality of cut is when the wood is moving straight down.
The tool rest height, in order to maintain the best scraping cut, is dependent on the distance between the top of the tool rest and the height above it the cutting edge of the scraper meets the wood. The two main factors that make this height a variable, is the scraper thickness when used traditionally, and the scraper width in the case of shear scraping.
The best way I've found to nail the tool rest height adjustment, is to use a block of wood that shows exactly where the centerline of the lathe is. (see photo) With the scraper on the tool rest, and pointed at the height block, it's easy to see if it's a match, or not......adjust accordingly.
(On the bowl exterior)
If the scraper goes above the centerline, it can be a dangerous situation because the wood is now moving TOWARDS the cutting edge, and can have a severe catch. If the scraper is presented to the wood below the centerline, it's safer because the wood is now moving AWAY from the cutting edge.......but, the further below the centerline you go, the worse the quality of cut will be.
(On the bowl interior), all of the above is the exact opposite......safer to go above centerline, but dangerous to go below......and best cut is normally at centerline. There are times when it's advisable to go well above centerline, strictly for safety reasons. There doesn't seem to be any hard-fast rules about this, because each bowl shape, species, thickness, rpm, etc., can, and does effect what works best.
The only hard-fast rules that are universal seems to be avoiding cutting above center on the outside, or below center on the inside.
Anyone who agrees, disagrees, or has any other comment, idea, recommendations, whatever.......is welcome to contribute to this thread.
