Toolrest storage
I use a mechanic's cart from Harbor Freight as a stand for my grinder. I keep the tool rests in one of the drawers on the cart. It keeps the rests close at hand while I'm turning, literally two steps from where I normally stand.
With a limited size workshop, I went for a solution fitting the empty space under my lathe bed extension. It's on wheels. Rarely used toolrests are stashed high on a shelf.
So far satisfied with it.
I have a small cabinet that that holds other tools sanding supplies my cole jaws and other odds and ends. On the side are my tool rests.
I have rolling wire frame carts, and keep the tool rests on one of the shelves. I do need a few more straight rests. I don't like the curved bar/support arm ones, and prefer the angled ones. May have to fabricate them myself.... The Steve Sinner ones do look interesting, but I want some more angle to them..
I don't have near as many as most of you do but I put them in a holder off the side of my tail stock holder. It's to the side so I can still easily stand and turn from the end of the lathe, which I almost always do on bowls and hollowing.
Thanks for all the ideas. I've been keeping mine on top of a drawer unit that sits between my lathe legs, under the bedways. Has been OK even in the shavings but now I'm getting too many and they want to slide off when piled on top of one another. I thought about an edge to stop the sliding but then the shavings would be trapped too. Others' solutions give me things to consider.
I have 7 and they live in a drawer near the lathe.
Just a random thought. Drill some holes along the edge and pop in some short dowels. Voila, a fence. Every 3 inches is probably enough to keep your rests corralled and let the chips pass through.
Odie, What's in the Folgers can?
Some good ideas here and I'm sure I'll draw from them as my collection grows. So far I only have 3 that I use on a regular basis. They hang on a pegboard behind my lathe within easy reach.
Just noticed one is visible in my whatyamacallit picture on the left. The other two live just out of view to the left.
That is the same question I had for Odie.
Like those French Cleats-- been using them for years but never knew they were French. I'm curious, did you use that so you could rearrange things as you go?
I love French cleats too. I use them for some things around the shop. When I move in a few years, in my next shop, the walls will be covered in a French cleating system. They are so versatile. I just don't have convenient wall space near the lathe where I am now.
Ya know Odie, something that comes up often in many of your shop photos is the wall space devoted to license plates. You could get a lot more turning stuff in that wall space!
What, and get rid of my license plate collection?......no way! :D
I believe you Odie, but can't you make up a better story? ;)
View: https://youtu.be/PWSx0bBiNIs
:D
OK, I've avoided admitting this.....but, I have this witch friend, and after appealing to her, I ended up selling my soul to the devil for the special formula in that Folgers coffee can. It's a special brew that I dip my turning tools in.....and, my tools get nothing but perfect cuts every time......just like magic!:cool:
Tom - Mainly for the flexibility it gave me trying to store 40mm, 30mm and one inch tool rests. Partially because I’m lazy when it comes to these types of solutions and this seemed the simplest.
