It sounds like an issue of not cutting the wood. That's not the end-all answer, but when you're talking about multiple species, some of which cut pretty darned clean normally, it sounds like a technique issue, using sharp tools the right way. If you've got tear out on both inside and outside on that many species, it has to be (sorry for this) you. Unless of course you've managed to pick up the oddlot ends from everyone else's reject bin...
We had a GREAT technical demo this month in our chapter meeting. It was all about end-grain hollowing. The demonstrator's point was that if you want a smooth surface, you have to defeat the end grain problem. As many folks do, he likened the end grain of wood as being a bundle of straws, fairly tightly held in place. If you drag something across those rough straw ends, some of them are going to catch on the tool edge and just yank the straw out of the bundle, causing a bigger area that is "catchable". Tear out.
One solution is to drill into the middle of the endgrain and then use a good sharp tool to cut across the bottom, slicing them straws on their sides, not dragging across the tops of them. Easier to show that speak, sorry.
Have you tried a hook tool or ring tool for cutting the insides? If you're using a scraper, have you made sure that you have a proper burr on the business end? Have you deliberately tried it WITHOUT that burr?
One man's opinions, YMMV. Keep trying, and do get in touch with your local chapter for help in solving your problems. Someone watching is worth MILLIONS of words. And certainly more than our blind opinions. 8^)
