The Baxter Thread Master is the most versatile Thread Milling Attachment available for wood lathes. Baxter's Thread master was designed to allow you to turn your object on your favorite lathe and mill the threads on another lathe if you so desire, or use one lathe for both turning and milling. This Baxter Thread Master can mill threads up to 5” diameter.
The Baxter Thread Master comes complete with everything required to mill threads using your lathe chuck or your face plates for your projects, including:
Includes:
1....Basic Thread Master
1....Auxilary Slide
1.... 1" x 8TPI Spindle Head 1....Threading Head (believe 16” pitch)
1....3/4" Thread Mill with 3/8" Shank
1....3/8" #2 Morse Taper Collet
1....3/8-16 Draw Bar for the collet
Bonus items that were purchased separately.
Additional 1/2" cutter which currently costs $49.95
Two (2) 1” x 8TPI faceplates which currently cost $29.95.
This Baxter Thread Master BTM-12.5X was built specifically for a Delta Midi lathe and can be used with the following lathes with no modifications:
Delta Model 46-460
Jet Model 1221
Laguna Model 12/16
This Baxter Thread Master BTM-12.5X can easily be modified to fit the following lathes with minor modifications:
Jet 1220 – requires swapping the riser block
Jet 1014 – requires swapping the riser block
Oneway 1224 – requires swapping the bed key and washer
Vicmarc VL150 – requires replacing the riser plate
The picture is from the Best Wood Tools website (bestwoodtools.com). The Thread Master is wrapped in bubble wrap in the original box.
Current Price is $625. Asking $450 plus shipping OBO.
I will be in Clearwater Beach, FL in the near future and could bring the Baxter Thread Master BTM-12.5X with me.
Please let me know if you have any questions.
Rick Bucker
Email: rickb5078@yahoo.com
Cell: 217-620-0221
Includes:
1....Auxilary Slide
Delta Model 46-460
Jet Model 1221
Laguna Model 12/16
Rick Bucker
Cell: 217-620-0221
