Using an Ipad as a monitor for hollowing system
Emiliano Achaval
Maui, Hawaii
hawaiiankoaturner.com
I have been asked by @randylarson how to use an Ipad as a monitor for a hollowing system. Since my set up is at least 2 years old, I do not want to give "old" advice. I would encourage anyone wanting to learn and know more about the use of technology in woodturning to join www.lucidwoodturners.com. But of course, here is an excellent place to ask, we will point you in the right direction. I'm curious to see if @AlanZ has a new way of using an iPad for the hollowing rig.
AlanZ
Resident Techno Geek
Oradell, NJ
Several years ago, I used an iPad with a mirror over its lens as part of a hollowing rig. I did the same with an iPhone. It was trickier back then because the Camera Lucida app did not support moire Orin get back then. I have switched to a computer based system because of all the advantages, but I will be happy to revisit the iPad approach.
San Antonio, TX
There are some endoscope and similar cameras on Amazon that support iOS, do you look for specific specs for the image not to be blurry and can be mounted far from the object and not close in a tight spot?
RichColvin
OTI Member
Marysville, OH
www.colvintools.com
What camera do you use?
Rich, I used the camera built into the ipad.
What an elegantly simple approach. I am guessing that the iPad is too heavy to move with the hollowing tool and that it stays fixed while the mirror moves with the cutter. If my interpretation is correct, is there any objectionable issue for the user dealing with size change of the displayed object?
At one time before realizing my folly I had considered removing the camera from my old iPad and having it tethered with a flex harness.
AlanZ
Oradell, NJ
Bill, I was using the camera on an iPad Mini or an iPhone mounted on the hollowing rig.
AlanZ
Oradell, NJ
And one can use an iphone’s camera and transmit to an iPad using the AirBeam app on both devices. Of course, the iPhone can also output, wired, to an hdmi monitor.
San Antonio, Tx
is there a camera, like one of the security cameras, that will send a video to the IPAD via an app or connect directly to the IPAD? I would like to mount a small camera on the hollowing rig and use the IPAD as the TV monitor. Just trying to keep from buying a TV and having a much bigger monitor to mount above the lathe. thanks to everyone for their input!
San Antonio, Tx
Grant; thank you for the info. are you using this for hollowing, focusing on the cutting tip and watching on the monitor? I read the specs and was concerned about the focus distance. how far is the camera from tool tip? thank you for your help.
AlanZ
Oradell, NJ
There are many cameras that can be viewed wirelessly via an app on the phone, for example, you can view security cameras from around the world if they make the stream public. However, the latency (delay in the image) would make them less than ideal for hollowing.
Ottawa, Ontario
Randy: Yes, I am using this for hollowing. I have a small Transformer hollowing set up from JT Tools. I changed the tool rest and rigged up the camera holder. It works very well.
I can move the camera up and down. The hollow forms that I've used it on so far range from about 6" in diameter to about 10". I bring the camera down to within an inch or so of the vessel. So far, the camera seems to focus without any issue.
