Vacuum chuck at altitude... what's a 'safe' pressure?
New Mexico
When I lived near sea level I could pull a vacuum in the high 20's. Now that I'm at 7,000' altitude naturally I don't get quite the vacuum... somewhere around 19-21. Any opinions on if this is safe or to be avoided would be appreciated. I get that it depends on the diameter of the chuck as well as size of the piece being turned.
Thanks!
Rick
I'm using a Gast pump that has pretty good CFM. Haven't had issues but wanted to get y'all's thoughts. I guess the real challenge is when the power goes out ;) .
You'll feel more comfortable about vacuum chucking when you've got a few more pieces under your belt. I like to have the pressure above 15, but not long ago the best I could get was about 10. All I had left to do was remove a tenon and sand the foot, so I went ahead and it worked out fine. Most of the things we do with a piece on a vacuum chuck are not really stressful to the connection--like sanding and nibbling off a tenon. We aren't generally rough turning a big bowl with a huge honkin gouge.
If thats a concern for you put a ”storage” tank in the circuit somewhere. It will take longer to draw the vacuum down but will also take longer to lose vacuum in the case of a power failure.
