My Vicmarc jaws have a wobble. I have made sure that the jaws and chuck numbers are aligned and that all eight screws are tight. Could the wobble cause be screws that are too long?
Are the screws firmly seated all the way in with the the screw head slightly below the top surface after tightening?My Vicmarc jaws have a wobble. I have made sure that the jaws and chuck numbers are aligned and that all eight screws are tight. Could the wobble cause be screws that are too long?
No. I'll be ordering #12mm screws this morning. Thank you.Are the screws firmly seated all the way in with the the screw head slightly below the top surface after tightening?
It scares me when anything is or seems loose on the lathe. I'll be ordering shorter screws today.Is the wobble happening while the jaws are holding/clamping something? If you aren't clamping something then the jaws will be slightly loose, and you can sometimes hear a rattling sound at low rpm.
There are two lengths of countersunk bolts for the VM100 chuck and two for the VM120 (and variants thereof). The different lengths are the shorter bolt for the range of jaws, the longer bolts are used for the cole jaw, jaws![]()
Thanks for your insight. I'll be ordering shorter screws today.Are the screws firmly seated all the way in with the the screw head slightly below the top surface after tightening?![]()
