Just playing around with ideas here.....
The Oneway banjo is for a 20" lathe, and the swing on the VL240 is a little more than 19 1/4".....(19.291")
I like the more secure holding power of the oneway banjo over the direct grub screw arrangement of the Vicmarc lathe.
@hockenbery, I think you're familiar with the Oneway banjos, and do you think it would be possible to shave about 3/8" off the top of the banjo?.....that is.....assuming there is a problem with using my existing 1" post tool rests on a change over from my Woodfast to the Vicmarc using the Oneway banjo.
Would there be any other problems I am not taking account for, with this combination?
Can anyone tell me for sure what all the differences between the "heavy duty" and regular stands available for the VL 240? (I understand about the enclosed base, and the stop bar.....neither of which I'm much interested in.)
I am assuming the VL240 lathe for both offerings is exactly the same......right? The difference is only in the stand.
Links:
Banjo:
Standard VL240:
branchestobowls.com
HD VL240:
branchestobowls.com
Any other comments, or considerations for the above lathe and/or banjo would be greatly appreciated.
Links:
Banjo:
Standard VL240:
Vicmarc VL240 ASM EVS 2HP | Branches to Bowls
The VL240 Lathes have a swivel head feature which allows for the headstock to turn its normal straight position out to 90 degrees. There are four individual pin-lock positions at increments of 22.5 degrees which aid in turner comfort when turning inside vessels and bowls. It has an accurate...
HD VL240:
VL240 ASM EVS HD | Branches to Bowls
The VL240 ASM Heavy Duty Lathe has a swivel head feature which allows for the headstock to turn its normal straight position out to 90 degrees. There are four individual pin-lock positions at increments of 0, 30, 60, 90 degrees which aid in turner comfort when turning inside vessels and bowls...
