Weird sanding marked
Hatboro, PA
I am trying to teach a student,and we recently came across these weird "sanding" marks. They can't be sanding marks because we have just been sanding with cloth backed in a circular motion around 700-800. 12" shallow bowl. I have seen this before, I am pretty sure in Walnut, but I want to speak intelligently to it, but I cannot. They only show at 220. We were at 400, saw a mark we missed and went down to 220, and they showed up. Too me, it's like a alien crop circle.... can't figure out how it got there, and it goes away not before too long. Please help!!
Thanks everyone!!
To me (guess) they look like tool marks that were not completely sanded at 150 grit. Many times I thought I got everything at 150 grit only to see something show up at 220. Just a guess.
My experience with walnut is that it just likes to show sanding scratches. But they often don't show up till I've gone to higher grits - smoothing the surrounding surfaces. So I have to back up to whatever grit-sized scratches I find - sometimes two or three times. And I usually have to sand walnut to around 600 or 800 if I want what would be, on other woods, a 400 grit surface.
I can see sanding scrathes(random arcing scratches) and what look like tool marks to me(circles going all the way around the bowl). Or possibly sanding scratches from the lowest grit(80?) I suppose. A shear scrape or negative rake scraper can help get rid of them, or dropping back down to 120 or 180 grit. When I hand sand I usually do it at a slow speed, maybe 150 to 200 rpm max.
Lots of deep inline scratches. Are you sure your student took care to keep the sandpaper moving, speaking of hand held pad. The grit will carve into the wood if held still.
When power sanding, be careful not to use the wrong side of the spinning disk. So, sanding the outside, as you’re showing, only the left side of the disk can touch, the side going against the direction of rotation. The right side, going with the rotation will put nasty swirly scratches. Also swinging around toward the midpoint of the bowl, you will be using more of the top and left side of the disk. Running perpendicular to the rotation is ok. Stay away from the center of the disk. To power sand near the bottom of the bowl, you need to reverse the direction of the piece or of the sander, to be sanding again against the rotation.
The best, and only way I’ve found to avoid the issue of dropping back two or more grades after finding ‘new’ scratches is to sand alternately by hand holding paper, and power sanding. Sand handheld (I sand at 750), you should start at 120 given the look of those marks. Inspect it carefully. The ONLY scratches must be inline! Zero swirls. None. Look close with a raking light.
Then, sand by power, the goal being to simply eliminate all of the in-line scratches. Sand with the same grit as handheld. All scratches must be swirls or random looking. Again, look very closely with a raking light.
Personally, I continue this process through at least 800,,usually to 2000. No surprises when the sun hits it!
I have two thoughts. One is that it's from the edge of the sandpaper. I don't KNOW that this is a problem, but I find mystery scratches sometimes, and that's my theory. The second is that it could be leftover loose grits from prior sandpaper. If you don't clear those out, you'll have 1% 80 grit on your 220 paper. (same thing if you pick your dropped 220 sandpaper up off the floor and return to sanding)
To get those sanding lines to go away I would do a test patch hand sand in the direction of the grain starting with one grit finer than the grit I think it was caused by. Then hand sand that area up to the finer grits to see if the lines went away completely. Start over going down a grit if it didn’t work.
Once you get the right culprit grit hand sand the entire bowl in the grain direction then resume sanding while turning as before. I’d check super carefully after each grit change and even hand sand in the direction of the grain each time. Caution your student not to use too much pressure on the paper or they’ll have the same issue all over again. Power sanding isn’t always the answer.
To add; consider your lights. As most know, sunlight shows all of the sanding and finishing flaws. The sun is a point light source, light rays only in one direction. Hard light that casts shadows in any defect.
Compare that with larger led shop lights, especially the strip lights. Great for most of our work since the light scatters, illuminating everything reasonably even. That scattered, diffuse light will hide all but the big honking scratches that you can almost feel.
Try it out. Use a flashlight only, then turn on general or lathe soft lights and watch the surface change, the scratches disappear.
There are 2 different marks I see, the semi circular ones and the linear ones. Both are probably sanding scratches. If I start at 80 grit, which I do need to some times, I go to 100, then 120, then 150, and 180. I do wipe the dust off with my hand which will push finer dust into deeper scratches and high light them. Other things that can cause mystery scratches, if you have 3 inch discs and 3 inch pads, the edge of the pad can leave 80 grit scratches, as can the edges of the abrasives. My preference when sanding is to rotate the bowl by hand for the first couple of grits which allows me to see what I am doing and make sure I get all the abrasive marks out. This is not too difficult if you have an articulated arm for sanding, which is one of my videos. I can not sand without it any more since it holds my arm with the sander so the only thing I have to do with that arm is squeeze the trigger. Another thing some one said, "Never take a finished piece from the shop into the house on a sunny day because sunlight causes scratches." This is a matter of having good lighting, and natural sun light is what our eyes have evolved into seeing best in. I have multi spectrum lights for all of my detail work.
Definitely sanding scratches. Nothing else makes tiny swirl marks. Always harder to remove on end grain. On walnut I wipe down the wood with a slightly damp cloth before going to the finest grits. Swells the fibers and scratch marks.
