What Lind of wood is this?
Jackson, MS
I kept the legs from an old ottoman that was thrown away and decided to turn one today. It was extremely dry but was a pleasure to turn. A bit dusty, about the hardness of cherry and little tear out. I’m pretty sure it was not made in the US and I don’t have a clue what the wood is.
I'm under an impression that luan/lauan, a tropical hardwood from SE Asia, is often used for furniture components like this. It is a common material for thin plywood as well. I may be wrong but that is my best guess. Also known as Phillipine mahogany, and other names.
I've done the same thing, scavenging legs off furniture heading to the dump.
I understood that there is no longer any true Luan. It was basically all used up for plywood and now they are using other species. If that is imported, my guesses are Acacia or Rubberwood (Parawood). Most likely Rubberwood.
Google says;
Key Details on Lauan Wood:
  • Availability: Due to excessive, unsustainable harvesting, authentic lauan is difficult to find.
  • Replacement: It is often replaced by inferior timber from Central and South America.
The first step is to look at the end grain of a small scrap sample. The article on the Wood Database tells how to get started. I found the book Identifying Wood by R. Bruce Hoadley invaluable. All that's needed is a single edged razor blade and a magnifying glass.. I use a low power stereo microscope but any magnifying glass about 10x will do.
A look at the shaved sample of end grain can tell much, perhaps most importantly eliminate a huge number of species it can't be. Ring porous? diffuse porous? ray characteristics, tyloses in pores, etc. Wood density can help narrow things down. Also, any US citizen can also send off a small sample for free professional ID.
