I have one plank of Padauk , no finish , that hazes over . Have a second and it does not haze. So here is the explanation :
A "haze" on padauk wood is typically caused by oxidation, where the natural oils in the wood react with oxygen in the air, creating a dulling effect on the surface, often appearing as a slightly cloudy film; this is a common characteristic of padauk and can be exacerbated by improper finishing techniques or exposure to moisture.
How to manage padauk haze:
- Proper sanding:
Ensure a thorough sanding process before finishing to remove any surface irregularities that could trap finish and cause haze.
- Choose the right finish:
Opt for a high-quality finish specifically designed for oily woods, like polyurethane or varnish with good penetration capabilities.
- Apply multiple coats:
Applying thin coats of finish with proper drying time between each layer can help create a good barrier against oxidation.
- Consider pre-treating:
Some woodworkers use a pre-treatment like a wood conditioner to help even out the absorption of finish on the wood.
