Witness Marks, Sanding Scratches, and other issues that crop up when trying to produce a superb finish...
It is an intermittent problem. The woods I'm working with right now, mostly maple and holly, seem to show scratches super easily. I guess that's why I started the thread, I'm running into it a lot. I was working with some woods not long ago, that didn't seem to have as much of a problem or a problem at all. I think most were harder woods...wonder if that's a factor.
I wonder if the problem is from starting with too coarse a grit. Tools, including particles of abrasive grit, can cause sub-surface deformation in metals and I wonder if it applies to wood as well.
I ran into that when I operated a small metallography lab in a nuclear facility. I embedded aluminum sample plates in epoxy. The thin plates were bonded by heat and pressure and my job was to grind the samples flat, polish and etch them, then examine with a microscope. I found if I first quickly flattened a potted sample with a very coarse grit disk then didn't remove enough material with successively finer grits, invisible damage from the coarse grits would remain in the aluminum just below the surface, only to be revealed in the later polishing stages. If I spent a little more time with the intermediate grits, this didn't happen.
I'm wondering if particles of very coarse grit might deform the subsurface of softer woods (sort of like a line of tearout) and be visible later, maybe when finish is applied. I've never seen this in wood but I rarely start with grits coarser than 320. Maybe prepare some test surfaces of side and end grain, start sanding the entire sample as usual, then sand one section as you do normally and spend a little more time with intermediate grits on another section. See if there is a difference when the finish is applied. I do this with quadrants of a squarish platter to demonstrate the effect of following the NRS with hand scraping.
Even if not using coarse grits, could the sandpaper used be a problem? I've tried lots of different types and some seemed to be less consistent. I finally found a type I'm happy with.
Also, what you described about seeing a scratch with your eyes but not in a photo: assuming the lighting is equivalent, could that be since the eyes see in stereo and the camera lens is mono? Maybe try looking at a scratch with one eye closed and see if there's a visible difference. Or twist your head 90-deg and see if the scratch looks the same.
These are wild ideas - it's hard to diagnose a visual thing through words! If possible, find a local mentor whose surfaces you like, get them to look at one of your surfaces where you see rogue scratches, and ask what they think. If possible, let them watch you work. With luck, maybe there will be an AhHa moment or at least get some ideas.
I knew a turner who was having all kinds of problems getting nice surfaces. When I watched him turn it was immediately obvious - in his case the problem was simply tools that were not sharp enough! His problem had nothing to do with the scratch problem you mentioned, but still, a second person might spot something.
I generally start at 120 grit. Sometimes 80 and sometimes 180. If you are starting at a high grit, you are probably spending a lot of time sanding. Assuming I am starting at 120 grit, I work out all the tool marks. Sometimes I'll drop to 80 grit to sand out tough spots. After getting all the tool marks out at 120, then the sanding at 180, 220, and 320 goes pretty fast. I rarely go over 320 grit. I never wet sand, for whatever it's worth.
In the book Good to Great, the author states, "Good is the enemy of great." The premise being that if you are only shooting for good, you will never be great. I would offer that perfection is also the enemy of great.
@JKJ sorry to hijack the thread, but regarding card scrapers, am I understanding correctly that you use the scraper with the lathe off? I haven't found any videos of anyone doing that. Tomislav shows using a card scraper as one would a regular scraper i.e. with the lathe on but that's as close as I've found. If you have any or know of any videos of using a card scraper in the manner you do I would love to see them.
Thanks
Some very interesting thoughts.
I have been wondering if this is solely a softer wood problem, or if I've seen it occur on harder woods. I'll have to experiment more. My current experience, the reason I started the thread, is the woods are on the softer side. The holly is probably one of the softest woods I have turned in the last year. I have some maple that is also softer, and a few others I'll be turning soon here that are...softish. I recently turned a number of eggs for easter, and, some were softish/medium, others were rather hard woods. One I actually don't have an identity for (I'll post a photo and see if someone can id), and, I don't actually recall having scratch issues with it. Its kind of a semi-figured, rather chatoyant piece of wood from a cutoff, that I bought just because they were selling the chunk for like two bucks, and I thought I saw hints of some rippled figure in it (which I did!) and wanted to do something with it. It was quite hard, turning it wasn't easy...BUT, I don't recall having any real issues sanding it to a real nice smooth surface.
On the first holly bowl, I accidentally just barely toughed my gouge to the outside at one point...the bowl wasn't spinning, but I'd just sharpened the gouge, and it left a mark. I sanded the mark out, but, there ARE subsurface fibers that appear to be damaged. I sanded it for a while, and the defect didn't entirely go away. Its diminished enough that it looks like a characteristic of the grain now, although I can see it, and I can tell its some damage to fibers that go deep enough, that I would have to over-thin the walls to fully and entirely remove it. So on woods as soft as Holly, I do think that subsurface damage (other than tearout) can occur. Now, the touch from the gouge was accidental. I am wondering now, though, if that's what's happening with the scratch marks...
For sandpaper. Early on, I kind of went scatterbrained, and I bought and tried every kind of sandpaper I could. I tried all the ones WW sell, several kinds of discs that Woodcraft sells, Abranet, various kinds of abrasive pads (the 3M types, which are mostly abrasive bonded to metal fibers), and then various kinds of sheet sandpapers. In the long run, I converged on just two types: Norton and Klingspor. I don't have a ready source of Klingspor locally, so I have to order it, while Woodcraft carries Norton. I have found the Norton seems to be far more effective than the other types I've used, except maybe Abranet (although, Abranet, the mesh stuff, sometimes has its own challenges). Norton seems to leave fewer scratches...I think that was the main reason I converged mostly on it, almost every other abrasive I used left WORSE scratches, especially the WW discs. It may just be a technique thing, but, norton with lighter pressure just seems to sand much more effectively, and has a lesser problem than I've experienced in the past. Klingspor seems to be about the same, however, I don't know that I've explored all the Klingspor options (since I have to order, and I haven't really had a chance to look at all the Klingspor options in person; I've heard some people mention fabric backed Klingspor, but I've only used paper backed.)
I do use Abranet some times. Its the mesh stuff, and I have boxes of the stuff, ranging from their coarsest to I think 1500 or 2000 grit. I like and don't like it. :P This stuff has a "grain" or a "direction" itself...in one direction its ridgid and cannot really be folded, in the other it rolls up or folds very easily. There are advantages to that, and it can be problematic. I used to use some of the lowish grits when I really had bad tearout to deal with, as the dust would go right through the paper and it seemed faster at correcting the issue. However, I have put a lot of effort lately into turning without tearout. As I mentioned in other communications to you, I do sometimes still get tearout, although these days, its a tiny fraction of the problem it used to be (I'm a total perfectionist, if you haven't figured that out yet! 🤣) So, I don't have to sand much to correct tearout, and for the most part, I try to correct it by other means...sheer scraping and scraping mostly. I think I am mostly successful too, and if I have to sand tearout out, it really doesn't take much effort or time these days. I had a little bit with the two holly bowls I've been working on, but I started sanding at 220, and it was gone in less than a minute. The thing that remains, then, is the scratch marks...
Regarding tools, thanks mostly to you, I believe my tools are quite sharp. They are sharper today, than I think they ever have been. I am not honing or stropping, only because I don't really have an effective means of doing that. I have a stroping pad, that I use for honing my plane irons, and I tried to use that on one of my gouges, and I promptly gouged a strip right out of the leather. :'( If I had a belt on a powered wheel, like the Tormek, I'd hone for sure, but ATM its the only thing I am not doing. I am sharpening on the 600 grit wheel now, and my edges are really nice. They might not be perfectly shaped, working on that. but they seem truly sharp now. Cutting the wood with a gouge is so easy, especially the M42 steel with my Carter & Son gouges. Now, one of the main tools I've been using is an HSS/M2 steel gouge I ground to a 40/40 shape, using Stu Batty's method of grinding (on a platform with 40 degree lines top mark the limits.)
I don't know if there is something wrong with this particular gouge, or if this is just the nature of HSS/M2 steel, but this gouge (and the M2 scraper I turned into an NRS recently) not only seem to lose their sharpness in a matter of minutes, but the edges also seem to literally deform. With the gouge, in less than 5 minutes most of the time, the nose goes from being a slightly rounded point (according to Batty's sharpening method) to a notched point with the notch offcenter according to the side of teh tool I've been using most. The wings will also deform a bit as well, although it takes longer. Once I notice this, I re-sharpen, but, I am honestly wondering if there is actually something wrong with this gouge. I've tried to avoid any bluing, and if I get any, I lighten my touch and keep grinding until the bluing is gone. I usually get a slight bit on the corners of the wings no matter what I do, but I don't really use those corners much. The rest of the gouge, as far as I can tell, has no bluing, but, I am wondering if having encountered that previously, if it still degraded the metal even in parts that weren't actually showing the issue? In any case, that gouge cuts REALLY well when its initially sharp, and I can get long sweeping cuts without tearout at all, which is one of the promises of the 40/40 grind. I think some of the minor tearout I do encounter, may be due to the rapid loss of the sharp edge... In any case, it works well, but, it requires resharpening constantly to keep it working well. Once I have the funds, a larger 40/40 grind in a better steel, is near the top of my list. The M42 steel does seem to hold its edge and its shape, well more than 10x longer than the HSS gouge does.
I missed this months meeting, but, I plan to start going to the front range woodturners meetings which are near the beginning of each month. Who knows, maybe I'll be able to meet someone at one of these who would be willing to take a look at my turning and give me some pointers. I think, its probably sanding technique, though, I think my actual turning with tools is ok. I still have some perfecting to to, in terms of following the curve as I cut, and cutting in continuous cuts (sometimes I still cut past the wood and have to back up and re-start a new cut), and learning how to use scrapers to optimal effect (I am fairly good with NRS on the inside of bowls, but I still occasionally bite the wood so I'm sure there are technique improvements I could make.) Overall though, I don't think its the tooling leaving the scratches (especially since most of the time, the scratches are usually perpendicular to the orientation of tooling marks.)
I need to find some harder woods, to try turning bowls/platters out of, and see if I still encounter the scratch problem. Maybe it is a softer wood issue, and maybe it is due to damaged fibers deeper into the wood. The holly really seems to have issues. Maple often does, and Cherry. I think all of the woods I can remember this happening most with, are under Janka 1400? I think holly is around 1000.
Ok. I finished the first holly bowl with the super blond shellac. Very slight yellowing, but overall it still maintains most of its nice light tones. I tried lacquer, and I definitely did not like the gloss on the holly, and wasn't terribly fond of the overall nature. Lacquer is probably fine on other woods, but not for the holly.
I used two coats of the super blond shellac. Let the first one dry thouroughly, and denibbed with 800 grit sandpaper. Noticed a lot of...I guess I wouldn't call them scratches....scuff marks? Very faint, kind of broad marks. This is an issue I have when sanding shellac, probably due to the clogging of the paper itself, and the shellac in the paper rubbing across the shellac on the wood, I think. I wiped it down with a dry piece of paper towel, which is slightly abrasive, and that largely cleaned up the scuff marks. I put on a second coat when everything felt smooth. Let that dry thouroughly (couple of hours, probably longer than necessary.) I sanded it back very lightly with the 800 grit.
Still had the faint scuff marks, so I took one of the pieces of advice from this thread: Picked up a handful of the holly shavings...these were pretty thin and light, but not the super fine fluff I get with sheer scraping...these were normal gouge shavings, fairly fine and felt somewhat soft. Used that to burnish the surface, and wow!!!! That REALLY helped!! I had to move my light around a fair bit to find all the spots that needed work, and I was able to eliminate every single scuff mark, and overall give a very dull, nearly totally flat, finished surface. I actually like it fairly flat...and I am wondering if I should bother with the Acks sanding paste and polishing wax at all...
The burnishing, since it smoothed out the surface enough to give it a dull sheen, DID reveal an area with a few small scratches, which I think are indeed in the wood itself, not the shellac. For one, no amount of burnishing with the shavings, seems to touch these particular scratches. They are smallish, so, either 320 or 400 grit scratches I would think. I'm trying to get a photo...it requires some very oblique light. IF I can get one that shows them, I'll share.
Overall though, burnishing with the shavings from the blank turned itself, really does seem to help. As a final surface cleanup tool, its better than any sandpaper or abrasive pad I've ever used. So thank you for the tip!!
I was kind of wondering if you might benefit from some buffing. I ( and many folks ) use the beall buffing system with three wheels. The first two wheels are abrasive and remove a lot of fine scratches. The third is carnuba wax that gives a nice shine. If the scratches are like sub 400 grit (lower grit) then it's not going to help but anything higher than that could well come out.
One word of warning though, if you have shellac on there then do not apply much pressure when buffing. If it gets hot, or even too warm you will have a real mess on your hands. What I do is I use shellac for "pop" and sanding sealer and then I use osmo poly-x which is awesome. That combo keeps things as light as I've been able to get when working with lighter woods. And you can buff the osmo no problem.
...seem to lose their sharpness in a matter of minutes, but the edges also seem to literally deform. With the gouge, in less than 5 minutes most of the time, the nose goes from being a slightly rounded point ... to a notched point with the notch offcenter according to the side of teh tool I've been using most.
How is it possible to take a chunk out of leather when stropping? Unless you are pushing rather than pulling the gouge or rolling it up on a wing while pulling.
Also, I don't understand how a gouge nose can change the shape that quickly while turning. Try a scratch test with a small file and see if the metal is properly hardened. If so, the file will skate and not cut into the tool. I use a number of different HSS tools they are all almost the same with the same grinds. I do prefer the 10V steel I get from Doug Thompson.
If the tool is not HSS but hardened tool steel, the hardness will be destroyed when you see blue. Blue from overheating HSS shouldn't make any difference.
I've heard people say one definition of a expert turner is the ability to make a continuous and perfect cut down the entire surface or curve. That's a great skill and a nice goal. But I think a more practical definition is the ability to stop, go back, and seamlessly pick up an interrupted cut. Under some circumstances a continuous cut is not practical.
Ask if the club has a mentoring program. In our club, those with experience can volunteer to be on the mentor list and provide what things they are willing to help with. Any member can request mentoring from any mentor. The sessions are approved ahead of time for insurance purposes - the club carries insurance (I think from the AAW but not sure) so if anyone is somehow injured both the club and the mentors are covered.
I can't image softer woods in general being the reason for problems. Many turn soft woods without issues as long as the tools are sharp. (I like to test for sharpness by shaving hair off my left forearm.) I've turned a lot of things from soft basswood to lignum vitae and they are all about the same except for variations needed in the edge presentation and the speed of travel. A mentor might help narrow this down, perhaps by trying the same cuts with your tools and with their own tools. Some are excellent with sharpening too, if needed.
Note that some specific pieces of wood may contain a lot of silica which can dull tools quickly. I guess it's just the way the tree grew and what it sucked up out of the ground. I got a slab of 8/4 walnut once that dulled a new Starrett bandsaw blade in about 18" of cut!
BTW, if you want to get scientific about sharpness, look at this sharpness tester. It uses calibrated fibers and measures the force needed to cut the fiber. I have one and at one time tested a bunch of edges to help evaluate my sharpening techniques. The guy who developed it told me it is popular with knifemakers.
I accidentally cut into the leather when I was moving it towards the top for another drag. I was moving semi-quickly, and the front nose of the gouge caught the leather and sliced it. Just an accident, but it took a strip of the leather clean off. Its not a belt, its just a piece of wood with some weights on the bottom and a piece of leather on the top. If I had a belt on a wheel, I would hone everything.
Its just HSS. I've never seen blue on my M42 tools. The HSS blues pretty easily. I don't know why it happens, all I know is, the problem occurs during turning, and it doesn't take long. Probably a different discussion for another threat, but, I am very curious why its happening. Either this is ultra cheap steel...it is happening on Hurricane brand tools...or...I don't know. All I do know is, it happens consistently, and takes a few minutes for the change in shape to start appearing. Its extremely annoying.
Sure, its probably more practical to be able to continue a cut. There is something though, about a continuous curve that you never stopped...that just has a nicer profile. If I can't get a continuous cut, I will often use sheer scraping to refine the shape in areas where I can feel discontinuity in my cuts. I am not able to just start right where I left off and pick up a previous cut...what I usually do is go back a bit, start real light, and continue the cut that way, but even that usually leaves something behind...if I can't see it, I can always feel it. Sheer scraping feels like a crutch, but, it does work to refine the shape without causing other issues.
The softness I don't think is a problem with the tools. I think it may be a factor in the problem with remnant sanding scratches... Just anecdotally, when I think about the woods I seem to have the issue with most, it seems to be softer woods. I don't turn a lot of very hard woods, and most of the time when I do, its not anything large, its something small. I do have some decently sized bowl blanks in harder woods, though, like rosewoods, and I am curious to see if I run into the problem when I sand and finish them.
I mean, I do get tool marks when turning, but the biggest problem I did have, tearout, seems to be largely resolved thanks to better sharpening, and making sure my tools are always sharp. But the tool marks seem to get resolved very quickly with some sanding, and that usually doesn't even take a low grit (I could probably start at 320 to clean up tool marks.) Its the remnant scratches from sanding, that show up most once I've put some kind of finish on and polished it to the sheen I like, that I usually see the issue. Most often, this is shellac...someone earlier in the thread did mention they thought shellac was the worst for this.
I am going to be trying out the danish and tung oils I have once I get to some darker pieces of wood here. I have always loved the satin sheen your pieces have, and I think you said most of your pieces are finished in danish oil. I am very curious to give your process a try and see how things work out. Or maybe a combination of your method and I think it was Aaron Harris who mentioned some of his process, which involved some wet sanding with oil midway or so in the process. I have not had a lot of luck finishing with pure poly, but danish oil, which contains the oil, some varnish and other thinners, sounds like it might be easier to use. So I'm very curious to see how it goes. Outside of the lighter woods I often turn, which I think may require these very blond/clear shellacs to preserve wood color, I am hoping danish oil will be a better and more effective finish overall. The tough thing for me to overcome with it is the length of time it takes to get a complete finish, before I can list items for sale. I was spending weeks with poly spring last year, and could never quite get a nice, clean finish regardless of what I did (always had some kind of defect, including sanding scratch marks from the wood and other little issues.) Maybe danish oil/tung oil with some varnish will be more effective though. Hoping!
Ok, spent the last two hours working on a little bit of sheer scraping then sanding with only 220 grit on the outside of holly bowl #2.
My habit, is to try and sand with the "grain" which for a bowl blank, runs from one side to the opposite (at the ends of which is the end grain) and along the other two sides. I sand by hand, however, it seems my technique isn't as "strait" as I seemed to think. What I've learned is, I guess, two things. It seems that the problem I run into, is probably mostly the lower grits, and perhaps due to my sanding technique and approach.
1. When I think I am sanding strait along the long grain in the wood, its often not as strait as it seems. The points at which I lift the paper, will often have arcing or curled scratch marks. On a round surface, it seems rather challenging to sand exactly strait actually along the grain, so even when I sand "strait" sometimes its at a bit of an angle to the grain. So all of this, can cause scratches are not perfectly parallel to the long grain of the blank. On the end grain areas, I will initially sand across them, strait with the long grain and around the blank to the other side. However I noticed I'll often go back and sand perpendicular to that, and sometimes even with some semi-oval patterns. Its the end grain, so, there isn't really a direction. This is where most of the tearout is, and I guess I work at any tearout until its gone, and the sanding isn't always in a particular direction, I guess I just sand however I feel is necessary to eliminate any tearout. I generally try to clean that up with sheer scraping, however this particular bowl's outer shape just didn't seem all that conducive to sheer scraping. It has a concave curve. I did not think to use an NRS until I had been working on sanding for a while, I suspect an NRS would have helped given the concave shape of the curve.
2. I have noticed that sanding with the long grain, seems to create scratches that are counter to the main...features...of the wood. The grain is of course strait "across" the bowl blank from one side to the opposite from end gran to end gran, and "along" the two other sides. However, sanding along that grain, often allows scratch marks to be notably visible against other features of the wood. I don't know whether to call these features grain or not...but, they usually form more of an oval-esque shape around the bowl, and do not necessarily follow the actual long grain. If I sand along these features, rather than along the grain, scratches seem to get hidden in the features much more than if I sand across these features. So after sanding the whole bowl exterior once, then spending time examining it closely, and finding plenty of marks that still needed correction, I re-sanded the entire bowl exterior again, only along the priminent feature patterns rather than the fundamental long grain.
Something else I noticed through all of this. There is the initial sanding, which is often about removing tool marks, tearout and other unwanted defects. I usually start with the lathe on, around 600-700rpm, and usually start with 220 or 240 grit. I'll sand until all the notable tool marks are gone, and will spend some time working in the bands where I know some tearout exists. I used to have horrendous tearout, and usually had to spend a lot of time sheer scraping or with a NRS, but I've learned to make much better cuts this year and my tearout is less common and far less wide spread, usually only existing in small bands in the end grain areas, and its not nearly as deep as it once used to be. It might only be several thousandths and even with sanding, it is usually gone in relatively short order. There were some spots on this bowl that were a bit stubborn, notably along the under side near the edge of the rim (not entirely sure what happened there, it was almost more like chipout than tearout).
Once I have all the tool marks and tearout taken care of, then I get to manual hand sanding with the lathe off. I will hand sand along the grain...well, that's what I have been doing. As noted above, when I lift the paper off the wood, this often leaves arcing or curling scratch marks, and they often seem deeper and more prominent than other marks. I think this is the primary cause of the issues I've been seeing once I've layered on some shellac and polished it. My technique here is not particularly great, I think, and after noticing how sanding along the grain was often counter to other more prominent wood grain characteristics/features that run in different directions, often an oval loop around the bowl, I started sanding along these features. This resulted in less noticable scratch marks, although when I lift the paper off that's still a problem. After the first pass, I re-sanded with an even lighter touch, to the point where sometimes I was just running the 220 grit (Norton, the blue paper) over the wood without any finger pressure at all (fingers weren't even touching the wood), and just the tension in the rolled over piece of sandpaper was all the pressure I had on the wood. It took a fair amount of light sanding, to eliminate any notable scratches that I found, which took some time with my lathe light set up such that I had very oblique light on the piece.
I WAS, however, able to clean up all the notable scratch marks. I haven't sanded with 320 or 400 yet, nor used shavings to do any burnishing. However, examining the bowl now, I am not easily finding any notable scratch marks. I'm going to sand with 320 and maybe 400 the same way...along the main wood characteristics/features, rather than the long grain. Its more complex to sand that way, but, those features seem to hide sanding scratches in general much better than just simplistically sanding along the long grain. I don't know if most people would just call these characteristics/features "the grain" or if there is another name for them. I also, am still not entirely sure what the best way to deal with end grain is...there isn't exactly a direction. I may sand up and down (from bottom to top of the bowl) initially, then perpendicular to that, but try to follow features if I can, I guess. The features in the end grain are different, though. Some of them are more like tight ovals from the top to bottom of the blank, rather than along the actual long grain. Other aspects, even more central to the end grain, are often just kind of a stippling. I guess the primary goal, whatever the case may be, will be to identify and eliminate any notable scratch marks at each grit, before moving on to the next, or moving on to burnishing with shavings.
It is still a lot of work, but...I think, with a clearer understanding of what is going on and with a little practice, the time and effort will diminish to some degree and I'll be able to get through it all quicker, and not have to spend so much time working on every bowl (or platter, or vase, or many of the other items I make), which should allow me to make more stuff overall. That's the goal, at least...well, that, and, just achieving higher quality and a more professional result in the end.
[sand] along the main wood characteristics/features, rather than the long grain. Its more complex to sand that way, but, those features seem to hide sanding scratches in general much better than just simplistically sanding along the long grain. I don't know if most people would just call these characteristics/features "the grain"
I never mentioned it, but after general sanding with and across the grain, I also usually sand along the “features” as you say, streaks of distinctive coloration, figure, whatever. Then coat with the naphtha (or whatever) carefully examine all surfaces in a good directed light, off the lathe, moving through every angle.
Sometimes such “features” are harder or softer wood than other parts of the wood, so hand sanding with a soft sanding block is important for me, gently scraping if I see anything I don’t like. (good thing I don’t have a mirror in the shop)
Maybe I need to redo my sanding video.... Well, I do. I remember Mike Mahoney commenting during one of his duo things with Stuart Batty, that he starts sanding with 80 grit and that he would be done in less time than Stuart. I am closer to that range. Most of the time I will start at 100 or 120 grit. I could claim that I could have sanded out every bowl I have made with 220 grit, but I would still be working on 3/4 of them. That being said, where I start depends a LOT on the wood. Some woods will cut more cleanly than others, which is the given nature of wood. Even pieces from the same tree will turn differently, and have cleaner or rougher surfaces. The same techniques will work with some woods and not others. My final cuts are generally a shear scrape. I am going through some bay laurel/myrtle and even a brand new forstner bit is smoking as I try to drill my recess into it for turning the outside. With this log, I will have to start at 80 or 100 grit. My tools are dulling more quickly, even the Big Ugly tool. I am having to finish with gouges. NRSs won't clean it up either. Now, I have been playing around a lot with "finish cuts". It seems that green wood will go much differently than dry wood. I have been turning some dry madrone, and with a NRS, I can easily start at 120. I may be able to start at finer grits, but starting at 120 is fine with me. My grit progression is 80 when necessary, 100 when necessary, 120, 150, 180, 220, 320, 400, and the walnut oil goes on with the grey synthetic steel wool pads. Many will consider this "over sanding", and perhaps it is. But, it saves me just once from having to go back and resand some thing after I am done, then it is worth the effort. I power sand only. I do make sure to sand with "opposite scratch patterns" both inside and outside on the bowls. I do this by changing where on the sanding pad I am contacting the wood and not reversing the drill, and having the video would explain this better.... So, on the outside, below center, and angled at about 45 degrees, then above center and angled at 45 degrees the other direction. The cross hatching of the grit arcs contrast each other and I figure it removes wood better, plus it can show if you "missed" some spots. I spend far more time with the first coarser grits than I do with the finer "polishing" grits since with them, you are mostly polishing out the scratches from the previous grit. Being able to "see" your sanding scratches seems to be helped by 2 main things. One is prescription reading or other glasses, and having "natural" lighting. This is where the "never take your pieces from the shop into the house on a sunny day, sun light causes scratches" comes from. The LED lights, when they first came out were mostly white. I was using a Blue Max lamp, which has a neon lamp, which was intended for needle point sewers. It was natural spectrum. These lights are some times sold as "therapy" lights for where it is grey and gloomy a lot. I am now using a "Bright Reader" lamp which is very bright and spreads the light around and is also a "therapy" lamp. I have several of them in the shop. Beyond that, I NEVER use the air hose to blow off the dust, even inside my sanding hood, because it sends dust up into the air and makes a mess. I do wipe my bowls by hand. Especially at the finer grits, this works the fine dust down into the scratches, and helps to high light them.
I have never tried the card scrapers. Just not sure if they would be efficient for production work.
I enjoy your ability to share details in your sanding process.
This was new to me, to follow the features. I am also noticing that some wood characteristics, such as bands of larger pores, often seem to follow these features, rather than the strait grain. I have a bunch of elm pieces that I turned in the recent past. I noticed that the pores occurred in bands with them, but didn't really wonder at the time why they didn't follow the long grain. These were all spindles, and sanding a spindle seems easier in general, although I do still sometimes run into scratch issues. It is interesting, though, that these often more meandering and curving features, are where the larger wood pores often are.
With the holly, I think it may be similar, only with much, much smaller pores. When I examine the surface of these bowls with very oblique, glancing light I can see physical differences in the wood. There are thin bands separated by wider bands, and I think the thin bands are actually the pore bands. They seem to be slightly harder, the other bands a little softer, and they often end up slightly different levels once I've fully sanded and then burnished with shavings. Its very slight, but now I'm recognizing that this is in fact an intrinsic wood characteristic, and not trying to sand through it. Sanding WITH the features not only hides sanding scratches or othe rmarks within them, but also enhances the differences in their characteristics.
?Its very interesting...
Based on my testing last night and this morning, I think most of the scratches are probably 220/240 grit, maybe some 320.
I also have the Beall buffing system, the three wheels. I have several different sets of wheels, depending on what I'm doing. I don't always like a wax final finish, so one set of wheels is Trip, White Diamond, Carnauba, another wheel is Beeswax, then another set of wheels is Trip, White Diamond, then a bare wheel that I don't load with anything, and just use for final cleanup to take off any remnants of the buffing compounds. I have other sets of wheels for buffing pens made out of resins or CA on wood (white diamond, the blue rouge that is as far as I know a veyr fine grit compound, but I honestly don't know whats in it...all its ever sold as is Blue Rouge. :P) to a very high glass like glossy shine.
I am curious, well I guess a couple of things. I get a pretty good satin sheen with shellac and just using Acks sanding paste and buffing that out with paper towel. I have buffed shellac in the past, and I did find it a very delicate process. So, first is, is it really even worth buffing shellac? Or is the risk of just taking it off entirely or creating a sticky mess too high? The other is...what are the most buffed finishes? The videos I watched some years ago when I sat down to really learn how to buff, were mostly pens, and Danish oil finished pieces. It seems Danish oil handles buffing really well and can produce anything from a nice satin sheen to a pretty darn shiny (but not necessarily glassy gloss) surface. I think I saw a couple of people buffing pure oil finishes (which they usually waited 30 days for the oil to cure enough), and I wasn't real sure if I was seeing any real benefit with just plain oil. I'm guessing Danish oil fares better with buffing, because it includes varnish?
I used to have a small can of Poly-X. I used it on a couple of bowls and a platter, IIRC. I was really very novice at the time though, and I didn't know anything about anything and didn't know how much I didn't know back then, and I don't think I applied the Poly-X well (IIRC, I may have even applied it with the lathe turning, which probably ruined the finishes overall.) I've had a few people mention Poly-X or other Osmo finishes (Top Oil?) that seem to have a very minimal impact to lighter woods. I am quite interested in using Danish oil on some medium and darker woods. I was going to turn some maple pieces next after these holly, but, I think I'm going to work on some Cherry and Walnut pieces instead, and see how Danish oil goes, as a lot of turners on these forums seem to have GREAT success with various forms of Danish oil (commercial or home made). I also have Tung oil that also has a varnish in it like Danish, that I want to give a try. I'll see if I think buffing is warranted on some of them and give it a try. I've mostly buffed pens, although I did buff some basic turned boxes and bowls in the past, and I did spend time learning how to make the most of buffing for pen making a couple years ago and its a staple part of my process for that stuff now.
@John K Jordan Have you ever created any videos or articles on how you use a scraper for bowls? I'm working with them now, and I can see my lack of skill. I want to make them a part of my available skills, though, so I can leverage card scraping if I need to, and it would be great to have some resources to learn from if you have any.
Seems like your attempt to sand a 3D round object with the grain is leaving pigtails at the ends of your sanding strokes. Try going back to basics and hold sandpaper (flexible backing is best) backed up by medium density foam, felt or leather while the work is turning at a moderate speed that doesn't generate much heat. If needed, use a card scraper to take out minor tearout - scrapers are wonderful tools, but very easy to dig deeper than the defect with an errant pass. Use pencil marks on the endgrain to gauge how much you are taking off - sand off the pencil marks twice with 320 and you should be below any 220 scratches. Go on up the grit sequence until you have an acceptable surface with imperceptible sanding marks.
Sanding isn't rocket surgery. High grit scratches should disappear quickly without a lot of work once the initial smoothing is done. Many successful professional bowl turners with excellent tool skills start at relatively low grits and refine the surface using rotary sanders and hand-held sandpaper with the lathe turning in short order and to a high standard.
If a gouge tip's shape deforms in the time another gouge merely dulls, toss it. Life's too short.
I actually do start my sanding with the lathe on. For the lowest grit, to remove tearout and tool marks, I sand lathe on. That is a relatively quick process, and seems to be quite effective.
However, at least to my eyes, that leaves a ton of highly visible scratch marks radially around the bowl. I start at 220, and I still see them very readily... I used to use a powered sander with sanding discs on foam pads. That was much worse than just sanding with the lathe on, to my eyes...
So, I honestly don't know, if I am just super picky? Or if there is some aspect of my technique that professional bowl turners have weeded out somehow? Rotary sanders, either inertial or powered (I have both, FWIW), seem to just shred the wood. I try to avoid using much pressure, but with an inertial you need at least enough to keep it spinning. The final result after using any kind of rotary sander just seems to be shredded wood fibers...
Perhaps some of this has to do with the finish used in the long run? I've mostly used shellac and the Acks. Someone mentioned earlier in the thread that shellac tends to exacerbate sanding defects more than most other finishes...seems to be my experience. Its easy to apply, not easy to prepare for. Mostly because my forays into poly earlier last year, were not very successful and I did not like the process (which could be quite long and arduous). I tried Danish oil some years ago, but that can take weeks or so to complete, and then letting a piece fully cure means it can be quite some time before and item is truly complete. That bothered me before, however, it is something I'd like to revisit. Perhaps Danish oil with some wet sanding would give me an entirely different experience with sanding in the long run. The notion of wet sanding with a DO (or Tung oil) finish seems to me like a potentially great way to simplify the whole process, if the wet sanding is more easily able to take care of sanding issues. Maybe then I could, well, not feel I have to spend a lot of time sanding before I apply the first coats of finish, then refine and polish things up with wet sanding.
Card scrapers are new in my tool belt. I haven't used them much before, and never on bowls or platters or larger items. So I am working on learning how to use those. I am a little timid with them, as on convex surfaces in particular, I seem to dig a little too deep and introduce scratches. But, I can see their value, when I'm able to pull that fine fuzz out. I don't recall if it was you or someone else, but I've also been leveraging my shavings as a final tool to clean up the surface and lightly burnish it, which produces a really nice final surface...but, only after I've spent the time to sand extremely well. I stop at 400 grit now, no farther, and let the shavings take care of what I was using 600-1200 or so to do previously. The next piece is going to be a platter, which won't have surfaces that are quite as curved, and I'm going to use card scrapers to clean up any tearout or otherwise smooth the surface for some practice.
I am just about done sanding the inside of the second holly bowl. I haven't had much success getting photos of the scratch marks (whcih, I am now actually largely getting rid of), but I can try to show off the surface of the wood. I don't know how it compares to anyone else's. I only really know my own work, from a first hand/my own eyes perspective, especially not with closer scrutiny. Pictures and videos online, never really reveal the true nature or quality of the finished surface. For both the outside and inside, I started sanding this bowl with the lathe on, until all tool marks and tearout were gone. I'd say 5 minutes or so each, is probably all it took, to take care of those major issues. The rest of the time is always trying to produce a clean surface that doesn't exhibit things like pigtails (thank you, for the term!) or notable deeper scratches. That could be 30 minutes or more for in and out sides of a bowl/platter, and for something larger (I have a few 15" or so platter blanks in my stack to turn soon here) it could be more than that. I am going to table turning the maple stuff, and switch to something a bit darker that I could explore Danish oil with instead, to see if maybe most of this is more (or at least partly) a shellac as the finish issue. If DO or TO help me back off a bit on sanding, then perhaps the longer time period before pieces can be listed for sale or given as gifts is a reasonable tradeoff.
Walnut usually shows scratches quite readily. Start sanding it at 120 or 150, depending on how your cutting work went. Then 220ish, 280, 320. Higher if needed. Then start all over again, see what happens. Tweak your process a bit here and there, see if it gets better or worse.
It only occured to me now, but sometimes with woods that aren't cooperating after sanding with a grit, I'll reverse the motor and sand it in the opposite reaction. It may help more for fibers that aren't wanting to shear away with the paper, but worth a try either way.
Ok. Hauled out my big guns camera: Canon EOS 5R and 100mm L macro lens. I had to angle the light a bit more extreme, so the scratches would show up on the camera. These are clear enough to me that I can see them in all but direct downward light. There are many others that require I adjust the light until I can see them. These scratches here, if I didn't do something to clean them up, would 100% show up very clearly with even slightly polished shellac.
This is 200 grit, light finger pressure, sanded manually along the long grain:
I then decided to turn the lathe and use some 320 with even lighter pressure (just enough to put the paper onto the wood but no more):
I do initially sand with the lathe on, at a speed of around 600rpm or so. I use that rpm, as it doesn't cause much heat, and one of the earlier things I learned was to "let the grit do the work" and to avoid burnishing while sanding. At high rpms you burnish pretty quickly, at least IME. At an RPM of 600 (or even lower for larger items) you can feel the sandpaper grit get a bit grabby on its own without much pressure. This ALWAYS leaves the radial kind of scratch pattern you can see above. To me, even without finishing with anything, I just can't accept that... Maybe this doesn't bother most people? Then worse, once I finish, if I don't do something to clean all of this up, the finish will often make these scratch marks even more prominent. Poly often will, shellac is pretty much guaranteed to. I wondered if my home made super blond shellac would, wondering if maybe only the Zinsser's would, and it does indeed. The super blond may in fact show them even more prominently. In any case...eh, nasty. Can't stand this!! (When I've used sanding discs on either an inertial or powered sander....oh boy....my eye will twitch!! They seem to just shred the wood fibers, and leave all manner of scratch marks of every kind going in every direction, with all manner of arcs and loops and other things.... I won't even describe what that does to me...)
The radial scratch marks here, are why I then turn off the lathe and switch to manual sanding after my initial work to clean up tool marks and tearout. I've generally sanded with the long grain of the blank when I switch to manual. However, as you can see in the first picture, that is often at odds with other features of the wood. Sanding with the more prominent features of the wood, though, seems to hide the scratch marks better, especially once I hit 400 grit and then lightly burnish with shavings. I follow the wood features with both the sandpaper and shavings.
I honestly only know my own work. I really have no idea, what most people's work looks like, or what most turners would find acceptable as far as scratches go. So many turners say they don't sand higher than anything from 180 to 320, and while some will sand to 400 or 600, practically none seem to sand higher than that. So, if 180, 220/240 or 320 are the stopping points...are people just not as picky about scratch marks then, as I am? Or something else...crappy technique, wood specific issues, specific sandpaper(s) used?
Maybe your eyesight is too good.
I have several benchmarks for finished sanded turnings in my locale, all pros who have made a living turning artistic bowls and hollow forms. Two of them use high speed pneumatic disc grinders with the lathe running, others use a mix of lower speed rotary, hand and random orbit sanding, as do I. They all, to my eye, produce very high quality work and they sell their work for good money in galleries and craft shows.
I don't think anyone on this forum is more dedicated to clean turning than Odie. Check out his post #29 in this thread sanding bowls
I definitely agree with hand sanding with the grain on spindle oriented work. Sanding with the grain on faceplate/crossgrain pieces is much more of a challenge, as you have found. Sanding into corners, like a quirk or rabbet, pretty much requires hand-sanding across the grain with the work spinning. Random orbit sanding produces a mesh or moire pattern that tends to hide crossgrain scratches and fool the eye, that's why it is so prevalent in cabinet shops. Hand sanding across the grain pretty much disappears if you go to 600# - to my eye, on most woods. If it makes you puke you will have to continue chasing that unicorn.
Why don't you seek out someone in your area whose work you respect and ask them for a critique on your sanding and finishing process? Trent Bosch is in Fort Collins and Cyndi Drozda in Boulder. An afternoon's private consult ought to be worth the investment.
No videos, but I've taught it to numerous students, shown at demos, and at workshops. Maybe when I get over the last surgeries AND write a new handout document for my next demo AND prepare for that demo AND service three diesel engines AND clear out some windfall trees...
Where does the time go? I spent hours today and yesterday teaching, at least that was something...
@Kevin Jenness I don't know too many people locally. I work from home, and was never one to get out much. I am going to the local front range woodturners meetings, though, so maybe I'll meet someone. Or at the very least, see some other people's turnings, maybe I can get an idea of what is...expected?
I honestly am not real sure where to stop. Some people insist that if you go over 320, you've closed off the grain and it won't absorb finishes well. I usually go to 400, as that is the first grit where I feel I can get an actual smooth surface, one that doesn't feel roughly sanded to the touch. I have a picture below of 400 grit sanding with some light burnishing with shavings. There is evidence, that was clearer after burnishing, of some scratch marks that still need correcting. So I feel I can do a better job, STILL! In my head, I'm sure that mark, even though its hard to see with the naked eye right now, would be a totally obvious defect once I put a finish on (although, I'm assuming shellac or poly, will be shellac in this case, but both seem to magnify defects.) So...I honestly don't know, is 600 ok if you are finishing with any kind of penetrating finish? Or is that more of an urban legend, the big bad unfinishable grit?
I think this needs another light pass of 400, along with spot cleanup where necessary (maybe even with 320 then 400 again) and then more work with the shavings, to clean this up so the surface is superb. At the very least, before I put a finish on this, I think spot cleaning any remaining defects like the marks in the upper center here, is necessary. Overall though, I am a lot happier with this, even though it took another 30 minutes to get it from the previous photo with the radial 320 grit scratches to this. And might take another 10-15 to clean up any remnant defects. Those remnants just show up better once the surface has been sanded to this level, so that's usually how it goes: Quick initial sanidng @ 220 with lathe on for tool marks & tearout; Manual sanding with the grain @ 220/240; Manual sanding with the features @ 320 w/ eye towards 220 scratch cleanup; Manual sanding with the features @ 400 w/ eye towards 320 scratch cleanup; Final cleanup/burnishing with pinches of shavings from the bowl (gives a slight sheen that seems to take the shellac really nicely.)
I have been learning, there are many individuals on this forum who have provided invaluable insights and are invaluable resources. Odie is one of them for sure. I was just reading a bit of his old thread on vibrations, and have already learned a few things, from him and several other respondents. Odie's comment about maintaining geometry, is something I've heard from some other people as well. JKJ for one, but others too. I myself have had issues losing optimal turned geometry with power sanding (which is what lead me to get the inertial sander, which I found troublesome to keep spinning in some places on the inside of bowls.) Despite what Odie says, man, I really...well, I guess I am realy wary of 60, 80, 150 grits, and I usually don't use 180 unless I have something truly stubborn that I can't get out with a higher grit.
I don't know if I have any old examples still lying around, of when I used to use 60 and 80 grits as my starting... Maybe I was stopping at too low a grit with those, it was 5 years ago now, and maybe I just wasn't sanding up to a high enough grit? I usually went to 240 or 320, and I don't think I went above those. In any case...those early bowls did not look good, and I always felt that the low grits just ripped the fibers apart, unnecessarily?
FWIW, sometimes, I wonder if there is a difference here, if you are turning green, or dry. Or perhaps the types of woods? I was just watching Mahoney turn some stuff earlier. I don't know what kind of wood he was turning, but it seemed to be softer than the woods I turn, which made me think it was at least somewhat green, and it just seemed to cut and sand...differently. He doesn't ever show full process in any of the videos on YT, so its hard to really know what he's turning, but it made me wonder if there are certain woods that just take sanding more easily than others, or if wetter woods handle it better. I have only turned dry wood for the last several years, due to the extremely arid nature of Colorado, and my early experiences with green woods checking and cracking badly while I turned them. Some were worse than others, but I rarely had a green wood bowl, even those I twice turned, turn out well in Colorado, so I just started making sure I let my wood dry before I turned it, and the last few years ALL the wood I turn is dry...usually very dry.
I'm sure your students appreciate your efforts. You are an incredibly skilled turner. I'd love to have the opportunity to learn from you! ;) I do hope things are getting better for you, John.
Last post for the night. Final cleanup with 400 grit, final burnishing with shavings (along the long grain this time, instead of along the features, which I think did better):
There is a characteristic I am seeing here, with this rather high end macro lens, that I can't quite feel with my fingers. Zoomed into 100%, and it appears to be remnant abrasions from the 220 and maybe 320 grit sandpapers:
Looks like mostly 220, which I sanded along the long grain with. You can see some 320 issues, which I sanded radially with the lathe on slow. I always thought "lower" grits (and I know they aren't particularly low, like 60 or 80) shredded the fibers...I think that is exactly what I am seeing here. So, now, I am wondering if some card scraping would clean that up. I suspect that's the key benefit of card scraping. I don't know if I am skilled enough with that, to try it on this bowl, and I think I'll probably spend a bit more time at 400 grit (even though these abrasions are mostly from the 220 grit, they were already mostly leveled by the prior 320 and 400 grit sanding, so the depth is very small...it might even be worth using 600 grit instead. I don't know if these abrasions can be cleaned up or not, or how much it matters. Maybe I only clean them up on half the bowl, then apply the shellac and see how the two halves compare...
Seconded.
Lots of info in this thread. I'll share what works for me on bowls.
  • At the lowest grit (often 120), I will get tool marks out with a drill sander using a 2" disc with the lathe off. A straight rotary sander is aggressive leaves a lot of scratches.
  • I then keep the lathe off and switch to my RO sander and remove all the scratches left by the drill sander using the same grit.
  • After I am done with the lowest grit, I usually switch to my RO. More often than not, I'll sand with the lathe off using a 3" disc (on bowls). Sometimes I'll turn the lathe on for this part, but usually off.
  • Move up in grits. If I did it right at 120, I shouldn't see scratches at the higher grits with my RO sander.
  • On porous woods, I'll apply a 1# cut of shellac for a sanding sealer.
  • Sand to 320 or maybe 400 on hollow forms and depending on the wood.
  • Yorkshire grit (optional, usually on HF and the like).
I'm no expert, but this has worked for me. The key, IMO, is the random oscillating sander. The sanding pad on a drill is very aggressive.
Well, some where I read that sanding scratches in wood are invisible to the human eye at around 600 grit. For sure, with metal it is far higher than that. Some only to to 320, but I can see scratches from that. I go to 400, then apply oil with the grey synthetic steel wool pads which are in that 600 grit range. I am experimenting again with the LDD soak, equal parts water and soap, uncolored soap not blue or green, 24 hour soak, rinse, dry, and then sand. I found an old piece from when I used it all the time and was amazed at how easily it sanded out. The myrtle log I have has been nasty. The soap soak is messy, but I have to see if it speeds up the sanding process. Maybe another video.
I sand with firm pads up to the 220 or so grit, then switch to medium pads. If I go over 400 grit, then I go to soft pads because you are really only polishing out scratches and not "sanding". Some do use soft pads because they figure they will get into corners better. Angling the pad works better. Mostly if you use a soft pad, the edges are sanding but the middle is not. Also, 120 on a firm pad cuts far faster than 80 on a soft pad.
I think it is important to consider the speed of sanding used for different grits, either by hand against the wood or with a rotating drill.
My general rule is to turn fast, sand slow. As mentioned before, most of my sanding is by hand with the lathe off. Can't get much slower than that.
I think I overcompensated last night, with too light of pressure for 400 grit. I re-sanded with 400 earlier today, and that did seem to start taking care of the remnants of the 200 grit abrasions. It was going to take a long time though, so I flipped the lathe on, put it to 400 rpm, and sanded with 400 until even my camera+macro lens couldn't see any remnants of the 200 grit abrasions.
I then, taking a cue from Kevin, decided to clean up the 400 grit radial scratch marks with 600 grit. I started with the lathe on, and in the end I was still seeing 600 grit radial scraches...they are pretty fine, and maybe for most people they would be invisible. Perhaps part of my problem is my close range glasses...I spent a fair amount of time working with my optometrist conjuring up a pair of glasses that give me very good close up vision, at the cost of not really being able to see past about four feet with them. :P So...I have very, very good close up vision with that pair... Too good, I guess.
So I then sanded manually, and just kept it simple and went with the grain. that seemed to do the trick. With the camera, I can see the 600 grit scratch marks, along the grain, but I can't really see them with my own eyes even with the glasses. Lesson learned, maybe just use lighter pressure with the low grits, and then a moderate pressure with the higher. There are two kinds of sandpaper involved, too. It is all Norton brand, but, after 320 grit which is dry sand only, the blue and white paper with the rippled color pattern on blue backing, Norton switches to their wet/dry paper which is black with a yellow or blue backing. So, there is actually a difference between the two sandpapers, and the 400 and 600 grits do need some pressure to do their work.
Anyway:
If you go to a soft and gentle hand sand with say 320 or 400 you will lose the sand lines here, or alternately use an inertia sander at this point, 500rpm or faster with 320 grit. The finish will be flawless due to the random nature of oscillations in a matter of minutes, keep the pressure light and work down from the rim. Ideally 3" dia so you can sand the centre or dead zone, you could at a pinch get by with 2" dia. I would up the speed for centre sanding, say around 1000 rpm and a light touch. I rarely hand sand, preferring instead to use this method.
I understand the theory behind random orbital sanders. Well enough, that I bought a pneumatic one a couple years ago, and used it for a good while. The theory is that because the scratches are randomized with an RO sander, they can't be seen. In theory, sure, in practice? I dunno...
This again brings me to the question what other people's work looks like. Maybe my expectations are just way too high, or maybe there is again something with my technique. I grabbed a medium pad, and found some 2000 grit 2" sanding discs, and gave it a whirl on this bowl. I have no option but to use a pretty light touch with this RO, as if I give it more than just light pressure it slows down significantly and the nature of the orbit changes. This kind of...scuffing, scratching (?), is all over the place, and when I try to sand these things out with the RO sander, more show up elsewhere, even if I manage to clean up the spot I worked on. I stopped using it previously, because I could never completely eliminate this sort of thing:
I tried with the central part, which produces tighter closed rings. The edge, which produces more strait lines and scuff marks. And the mid part of the disc, which produces the above. This bowl has some tight curves where the wall meets the floor, and the only thing I can get into that area is the edge of the disc, and that produces largely radial lines and scuff marks. I've tried every disc I could get ahold of over the time I was using this previously...probably 7 or 8 different kinds of discs, 2" and 3", along with numerous different kinds of pads or other firmer foam bases for the discs. I had the above kinds of issues on everything I sanded with it.
Another concern I have had with powered sanders, is the potential risk of changing the geometry of what I turned. I originally started by using Kent Weakly's method, of only sanding from near the edge of the disc, lathe off, and with that edge oriented along the grain. Especially with lower grits, I felt changes in the surfaces when doing that, undulations or what have you, that I didn't want. I then switched to just sanding more normally with an RO, without spending too much time on any particular part of the disc outside of absolute necessity (such as the corner in my bowl.) I still had visible scratch marks or scuffing like above.
I probably worked at it over an 8 month period of time, before finally throwing in the towel. I really wanted it to work, because I otherwise end up spending a ridiculous amount of time sanding, which I don't like. This thread and my recent experiments, have taught me some new things, and I think I could improve my sanding speed more. The buffing with shavings does seem to give the final surface a nicer appearance, although I don't know how much it helps with any finishes. I also am thinking I need to account for the differences in sandpaper and grit types when determining necessary pressure. I need more with 400 and 600 than with 220 and 320. Very different kinds of grits/papers though. I also learned that sanding with the features of the wood, can resolve some issues that sanding with the grain cannot, and often those features are more than just color differences, but may also have density and porosity differences as well.
After sanding with the RO (at a whopping 2000 grit even!!), I think the manual 600 grit sanding (see my more recent photos) seemed to produce a fine result. The macro lens does pick up the 600 grit scratches, and it looks like I did manage to follow the long grain pretty darn closely with my last bit of hand sanding with 600, but I can't see any of it with my own eyes (without any glasses, nearsighted; or with my normal pair of glasses.)
I suspect there is something wrong with my RO sanding technique, or perhaps all the sanding discs I've used are really just crap, or maybe I'm using the wrong kinds of pads, something like that. In any case, I have been so far unsuccessful in getting the kind of beautiful wood surface I have wanted with RO sanding. I wish that wasn't the case, I would love for my sanding efforts to require far less time than they do...
Jon, here are a few random shots from pieces around my home. All are just oil finished (no glossy surface), and probably no wax. I don't own any mechanical sanding devices for lathe work, all sanding is by hand on the lathe. All pics shot with 2x magnification with my phone. Except for the last one (maple), which is a bit lazy looking on its interior but looks perfect on its exterior, for the rest, I had to study that surface up close under good, direct light to see my leftover sanding scratches. (Red lines indicate general area and shape of scratches.) Once they are back in their place on the shelf or table under normal light, and my eye is more than 10" away, they all look great and perfect and flaw-free. And to every person in my life that has ever held them in hand to express their pleasure and happiness with them, they are indeed flaw free. And I'd bet a dollar that if I had any of your turnings in my hands I'd accept them as perfect as well, as hand-made object of art made from imperfect materials with imperfect methods by an imperfect human being who strives to do his best. And honestly, maybe that's enough. It is for me. Great work!
Now, stop looking at it so hard, and go make another one!
Nah use the free wheeling type, no power it will produce the best finish, this type
@Steve Tiedman Thank you so much for the post, Steve. And for the pictures! Its probably as I expected, my disease is well progressed: Untenable Self Expectation! :P
This has been one of the most helpful posts in the thread. I really, don't get to see many other's turner's works up close. Certainly haven't in the last couple of years. So I am evaluating in almost total vacuume.
I think I'll start simplifying my process here. I've made it rather complicated, and I think I can achieve the same results, with less effort. I frequently, usually, sand lower grits both lathe on and off. So 220/240, first on, and I'll work at things until all the tool marks and anything else are gone or otherwise corrected. But then I guess that's where my obsession starts to kick in, and I'll sand with 220/240 with the lathe off, along the grain, but with a lighter pressure. I'll work at things until I can't really see any notable scratch marks, but this is often hard as the wood fibers are usually not in good shape at this point. Then I will often sand 320 both lathe on and off again. Sometimes just lathe on...so that I'm sanding across the manual sanding marks left by 220/240 grit. I then also spend a fair amount of time hunting around for any notable scratch marks that I then try to remove. This 240/320 scratch removal is always done along either grain or feature lines. I will then sand with 400 lathe off, along the grain (or now, features...which I guess would include rings, branch ring patterns, knots, or any other feature), and sometimes 600 lathe off. I was for a while, then going to 800 and even 1200, which I guess was more about burnishing a bit, which then makes deeper scratches pop out much more readily. I'd then correct those with 600.
After this thread, I think I'm just going to simplify it all down to this, as this was the final overarching process I did on the last holly bowl, and it seemed to work fine:
Lathe On: 240, 320, 400
Lathe Off: 600, manual, long grain (and then possibly along features, I guess it depends on how well the long grain hides the scratch marks)
Finally: Little bit of light burnishing with the wood shavings from the same piece
For spindles, which I often get a better starting surface with, I'll probably drop 240 grit.
I think I've been over-obsessing about removing visible or notable scratch marks, AT EVERY GRIT. I'm now just going to obsess over that, at the final grit. If I can't correct specific notable marks at that final grit, I'll back up to a lower as necessary. Hopefully this will simplify the process and speed things up. I have three more holly pieces to make here, so I have plenty to practice with using this same, semi-softer wood.
Hmm, are those random orbital as well? I have an inertial sander...I can give it another try. I think mine just spins though, without any kind of RO action. I thought you mentioned RO. I've also tried with sanding attachments for my powered drill, which, I think is just too powerful, and if you overpressure with it it WILL damage the geometry. :P
If there are RO inertial sanders, I was unaware of that.
You're welcome, Jon, happy I could help. And from a distance, I'm going to mostly agree about your self-assessment;)
Keep the 150/180 grit nearby, you may find it useful.
Those sanders hughie showed, those are just spinners, no random action at all. I've got one somewhere in a drawer... They feel a bit clumsy to me, and I don't want to buy disks. I'd rather spend that cash on a nice pizza after an afternoon in the shop.
@hughie Those are some interesting sanders. I remember trying to figure out how to make a low profile one a while back and couldn't figure out what parts to use. Do you have a recipe you recommend?
I've come to enjoy sanding (by hand, with the lathe off.) It's kind of a zen thing. Comfortable chair if my legs are tired, good light, no rush, relaxing time.
Well, it would be nice to see more people's work and see where mine falls within the spectrum. But, I think I've learned a few things in this thread, and will be able to cut down my time and effort sanding, but still generally achieve the same results.
I think most of my issue is the amount of time. If I can cut it in half or more, and do hand sanding for the last grit or two, to really clean up any radial scratch marks or anything like that, then I think I'll be happy. Maybe I'll get to a point where I enjoy it too. ;)
For these first two pieces of holly, though, after having gone through this thread and process, I believe I am satisfied. I spent a ton of time on the second one, but it was all for the learning. Its better than the first, which actually was pretty good given my new understanding. The next several should go faster, and I am hoping sanding will be less of a hassle.
