Congratulations to John K. Jordan winner of the June 2025 Turning Challenge (click here for details)
Congratulations to John Shannon"Cherry Bowl" being selected as Turning of the Week for June 30 2025
Anyone have luck using this jig with a 6” grinder? Or is meant to be used with an 8”? I understand the grind angle will be slightly different, just wondering if it will still work pretty well.
I've been using the Wolverine with a 6" grinder, it works fine. Set it up according to the directions, with the axis of the grinder 6-1/4 to 6-1/2 inches above the surface to which the Oneway bases are mounted. As to the angles, set them according to your tool bevels. The tools won't know that they are being ground on a 6" wheel as opposed to an 8" one (although the "hollow" of the grind will be more pronounced).
I've used the Wolverine jig on my high-speed 7" grinderfor 22 years. Bought my first 8" CBN wheel in 2013 and added a second CBN in 2015. Then added an 8" slow-speed Rikon in 2018. The Wolverine worked in all instances.
