WTB Sphere jig
Iota, LA
Anyone have a good used sphere Jig laying around collecting dust, I’m interested. I need to make a few ball for a school project.
Do they all need to be identical? Do you have diameter specifications? (Hope you're not juggling Lignum Vitae. :))
You might state the lathe you have. I am very familiar with just one jig, the Vermec (the best, IMO), and it is ordered depending on the lathe size and bed gap.. You can order parts to change to a different size lathe but they come from Australia and might not be cheap. If someone has a Vermec, for example, "laying around gathering dust", it might save some back and forth communication if they know what lathe you have.
But I've also turned a number of spheres without the jig using the "Soren Berger" method, using only a spindle gouge. They were not difficult. Turning "a few" wouldn't take long, maybe make one first for practice.
Typically, after turning by this "sub-division" method, I'll part off the sphere and remount it between wooden (or Rubber Chucky or similar) cones to refine the shape if needed. Do this on several axes.
Pro turer Mark StLeger starts as others do with a cylinder the exact length as the diameter and draws a pencil line around the exact center. His advice when turning: approach but never cut away the line! He uses a clever aid: moves a short piece of squared-off PVC small pipe over the surface to test the curvature. He demos making four spheres of identical size, makes a little base, with a groove, stacks the spheres - if made well twisting the top one makes them all spin. Clever! I have this onw in my collection:
More on turning by hand in this thread.
Dennis put it all down on paper.
A forum or web search might show more.
If really interested in a jig, John Lucas tested several. I think some weren't so good, not so sturdy. I loaned him the Vermec and I think he liked it best, very heavy, solid, built like a tank. I don't know the situation now but when I ordered mine from Australia I had it in hand in two days.
If you saw how the Vermec was made you could probably make a similar one given the right tools and cutter. (The Hunter #4 carbide cutter is perfect.)
