Looking for the mounting plate (part the platform mounts to and inserts into mounting base). I have a Oneway base adapter if you have a Wolverine system you'd like to use your platform with - even swap.
I'd also buy just your mounting plate if you already have the Oneway adapter.
Wouldn't have a problem buying an entire platform assembly either (2" wheel cutout preferred)
**What I have is on the left, what I need is on the right**
