Not bad for something that was destined to be mulched! I would be going back for the rest of it too...But I like it. I got this at the county tree dump and green turned ten bowls from 10-11 inches diameter and 5-6 inches deep. I've got the end grain sealed and in paper bags. I'm going back tomorrow and get the rest of this tree. There is a 10 ' x 25" log still there. Any ideas what it might be?
View attachment 29367 View attachment 29368 View attachment 29369
Initially I thought that it might be figured soft maple that has a lot of spalting, but it seems to have a strong delineation between early and late wood which makes me think that it is something else. A closer examination would be needed to make a positive identification. Most wood species can be identified by closely examining the end grain under about 10X magnification. "Identifying Wood" by Bruce Hoadley is an excellent reference book for woodturners. If you can take macro shots with your camera, a sharply focused close up image of a clean slice across the end grain that shows the arrangement and size of the pores might help identify the wood.
Looks like maple to me. Take a close look at the tree limbs when you go back. If the limbs have alternate branching then it's not a maple tree, but if the branching is opposite then there's a very good chance this is maple wood. Also, see if you can find any leaves from this tree.
Ron, it's pretty warm & humid right now so don't be surprised if this maple starts growing mold if put in a bag too soon.
As a learning exercise, try soaking one of the rough turned bowls in a tightly sealed container of DNA (De-Natured Alcohol) for a couple of days in order to speed up drying and lessen the chance of cracking. Then see how the DNA bowl compares to the sealed/bagged bowl in order to know when it's worth the cost for using DNA. I mostly dry rough blanks using a small homemade kiln when there's a lot to dry one time, but so far the DNA I've tried on cherry bowls has really helped (retains a cherry color better, no mold issues & lowers chance of cracking).
Btw, another commonly used acronym is 'FORD' wood as in "Found On the Road Dead".
Thanks, Karl, I've got something that will probably work. I built a 2'x4' egg incubator several years ago when we were hatching chickens and waterfowl but I haven't used it in a while. It has a controller that regulates the temp to 1/10 °, bottom vents to regulate incoming air, and top vents to regulate outgoing air an humidity. I'll go weigh some bowls and start experimenting tonight.
This is a link to the cheap controller that I've used for several years. You can run a computer fan to eliminate warm and cool spots.
https://www.amazon.com/WILLHI-WH143...1559169894&s=gateway&sr=8-1-spell-spons&psc=1
