Do I go forward, go backward, or give up?? Here's where I'm stuck: cherry bowl, 3 coats Waterlox, well cured. Started 3-stage Beall system with 4" bowl buffs. Stage 1 EEE went on nicely & removed some tiny scratches. Stage 2 White Diamond is causing obvious streaks, in whatever direction I hold the bowl against the buff. Too obvious to ignore. Have I gone thru the finish? Do I keep on pressing the diamond, go back to EEE, skip to Stage 3 Carnauba, or???
Thank you!
Thank you!
