All good advice, so far.......
(I'm using a Wolverine w/Vari-grind jig, and also do many straight grinds using just the V-arm.....the techniques described in this thread apply to both methods of grinding a bowl gouge.)
The point to remember is there is "blending" of ground edges.......it's not one continuous motion from one wing, around the tip, to the other wing. Any of the methods described will produce the desired result with practice. What you want to end up with is one continuous sweeping curve of the cutting edge (without facets or abrupt changes in the grind) all the way from the furthest point on the wing around the tip, and continuing to the furthest point on the opposite wing.
As Robo Hippy points out, the wings don't need to be exactly the same on both sides. You never use more than one wing and the tip for any cut, so either wing only need to have a smooth transition to the tip to have a good cutting ability.
Added to the above methods described in this thread is starting the grind on the furthermost point on one wing, and sweeping around to past half way around the tip......then do the other wing in the same fashion, blending one side to the other.
I use a combination of all the methods described by all those who contributed to this thread. The determining factor is the looks of the gouge you intend to grind. Depending on how you "size it up", will influence just how you want to go about it.......
A "V" shaped flute, from my experience, is a little more difficult to get a good transition around the tip. For this reason, I don't like them as much as a "U" shaped flute, but I have a few of them......so, I deal with the associated difficulties. I'll be willing to bet this is the source of Robert's difficulties with sharpening, in his original post. You just have to arc the grind around that tiny little tip too fast to have good control over the transition from a gradual curving wing to small radius tip, or vise versa.
From what I can tell, I see no advantage to using a "V" shaped flute, but there are definitely disadvantages to grinding them. For any practical use, I feel that if a smaller tip is wanted, then a smaller gouge with a smaller "U" shaped flute is the better solution. For cutting wood on the wing only.....then the flute shape makes no practical difference.
As usual, NONE of this is to deny that others might have differing methods that work for them.......I'm just explaining what does work for me.
