I just finished a 2x turned cherry bowl and power sanded it to 400 grit. I raised the grain with alcohol after 150. I was able to get out almost all of the tearout- certainly good enough for a salad bowl.
It turned out very nice and really felt smooth. My shop is in my garage. It was raining when I went back to the house and a few drops hit the bowl. The raindrops raised the grain again- much more than I would have expected.
I let it sit for 30min or so and sanded the rainspots with 600 grit. Felt smooth, but I could still see the raindrops. I put a coat of tung oil on. I figured the drops would blend into the surface after the tung oil- I was wrong.
I've wiped the surface several times and will let it dry until I can't feel any oil, but those spots are still going to be there. I'm hoping a good rub out with 0000 wool or scotchbrite will get me to a consistent surface for another application of oil.
Am I on the right track? Tung oil is new for me so I'm not sure the best approach to fix this.
Thanks
Dick
Thanks
Dick
