I just wanted to report on an alternate purpose for soaking rough-turned pieces in denatured alcohol. (Note that I will never use 'DNA' as an abbreviation for adulterated ethanol, since that acronym already has widespread acceptance for a VERY different chemical!).
Many of you will recall that "alcohol soaking" was popularized by Dave Smith some years ago to shorten the dry-down time for 'wet' rough-outs. After a while of experimenting with that method, I found that with the exception of a few species of wood (mostly "fruitwoods" in the Rose Family), the hassle of alcohol soaking was not worth the cost or extra effort, and I have since just used Anchorseal or paper bags to slow down the rate of simple air drying on my roughed bowls and vessels.
I did want to report an alternate use for alcohol soaking..... cessation of fungus activity. In mid-April 2012, I was given most of my next door neighbor's river birch by the tree crew who took down the tree - mostly 18-24" diameter log sections. They were stored on my driveway under "blue tarps" as I slowly whacked away at them when I could - but of course I never have as much turning time as I'd like, and at least half of them were actively spalting throughout the summer and fall. When the threat of snow came in December, I made log half sections out of most of them, and stored the decent pieces in my garage. On January 12th this year, I did a demo for the Des Moines Woodturners, and even though the wet piece of river birch log I used was fully frozen when I cut the round on the band saw, it turned superbly, and gorgeous zone lines and "shades of gray & brown" were exposed during my demo; just a beautiful piece of wood! I brought the roughed blank home from the demo wrapped in a plastic bag, needing to get it coated with Anchorseal and start it drying, but had forgotten about it for three days due to the start of our Spring semester here, and the "stuff" I had to do to get classes going. Three days after I roughed the bowl, I remembered that I still had to Anchorseal the blank and get it out of the bag. When I opened the plastic bag, I was greeted with thousands of fine, white fungus filaments covering the entire piece! I decided immediately that this was a good time to soak it in alcohol, and essentially "pickle" the living fungi. This worked REALLY well - I even put the alcohol soaked and surface-dried bowl BACK IN a plastic bag to see if any additional fungal growth was detected - but NONE after 4 days at shop temperature! I then coated the end grain with Anchorseal, and about ten days after the alcohol soak, the moisture content of the spalted river birch was below 15% (measured the tenon and rim with a Delmhorst J-2000 moisture meter; starting MC was over 30%).
Those of you with similar situations of having 'active growth' fungi in blanks you've turned should consider alcohol soaking, not necessarily as an aid to speeding-up drying, but a method that stops the continued growth of fungi to prevent further degradation of your roughed pieces.
Rob Wallace
Rob Wallace
