- Joined
- Apr 1, 2015
- Messages
- 603
- Likes
- 443
- Location
- Sitka, Alaska, United States
- Website
- www.zachlaperriere.com
I'm pretty much obsessed with natural oils. And by natural I mean: no synthetic or chemical dryers or thinners. I just want something that my pickiest customers feel is food grade.
So I'm sharing what I'm hoping will be my final oil for almost everything. It's a blend of pure tung oil, citrus oil (d-limonene), and tree gum rosin. Fun fact: 100% of this oil grows on trees.
Until recently I've been using Tried and True Danish Oil. I like it: but it needs to go on thin and then takes a fair bit of rubbing out to get surface dry. Corey's Tung Oil also needs to go on thin, but the oil viscosity is much closer to water than Danish oil...which means it's faster to apply.
I've been applying Corey's Tung Oil with the bowl still on the lathe. First I wipe it on a little heavy with the lathe power off, then turn the power on and buff the oil in with some friction heat. I use a 2" X 2" cotton cloth, but official safety protocol says only use paper towel because a catch on a large cloth can grab a finger. That's why I only use a small cloth.
One coat seems to be enough for basic use, but repeated coats build and given even greater depth. Tung oil seems to have the deepest "wet" appearance of any oil I've used. I'm seeing greater figure and even a subtle chatoyance in bowls that I've turned dozens of other bowls from the same tree but not seen the chatoyance with Danish oil.
The citrus oil smells great and gets the oil in deeper than straight tung oil. I can't really comment on the tree rosin, other than to say I'm really happy with the finished oil. My early tests show it to be very water resistant. I should say that the true test is a year or so of regular use, and I just haven't been using this oil long enough to have that experience. One thing I'll say about tung oil is that it has a reputation as being the hardiest of the natural oils.
Here's a mountain ash (rowan) small bowl still on the lathe. The picture is just a crummy iphone picture, but you can see some of the figure coming through from the crotch, which was only a small crotch.
I met Corey 25 years ago and built a skin kayak with him in his shop in Anacortes, Washington. He's an amazing and ingenious woodworker and has specialized in building traditional wood frame kayaks and umiaks for somewhere over 30 years. His dad is a retired chemist (and the first to import d-limonene to North America) so Corey approaches chemistry with that background.
For full disclosure, I don't have a financial connection with Corey, but he is an old friend that I'd lost touch with until I looked his company up and saw that he's selling tung oil. Here's his tung oil blend on his website. He also sells pure tung oil and other ingredients:
https://shop.skinboats.com/Coreys-Amazing-Tung-Oil-32-oz-cato.htm
