After 33 years with my Woodfast, a Vicmarc VL240 is now on the way!
I discovered that the Oneway bowl steady cannot conveniently be positioned on both sides of a bowl without changing the post position. This is especially true for when the headstock is rotated.
Because of this, I now have three Oneway bowl steadys! The one I had been using for years was cut down to accommodate my old 16" Woodfast lathe.....and is not tall enough to use on my new Vicmarc VL240.
Every day, it seems like, I have to modify and/or buy or make new tooling to use for the new lathe!~ :(
=o=
Well, I've never met anyone who has expected more (i.e. purpose suited customization) from an off-the-shelf machine as you, based on my observations on this board. That's not meant to be a positive or negative comment, just simply an observation. Remember, it did take you 33 years (or 10, or 20, or...) to get your Woodfast just right for your purposes.
I think you are on the right track, though. I don't see how there could be any other option, shy of a ground-up custom fabrication from raw materials.
That lathe is simply one of the best out there, but that is relative. Keep that in mind, because we can't foresake the possible, the expected, of the very, very good for the improbable/impossible of the perfect. You're the epitome of the shadetree woodturning engineer, you'll figure out how to make your new lathe one step closer to perfect.
I can't help but ask, though, and I ask because I am certainly not at the talent level of you (nor many on this forum), but how are others achieving upper echelon results without a similar level of heavily modified, customized, machines? That's probably more of a rhetorical, maybe philosophical question than anything. Food for thought, for insightful thinking, maybe not debate.
I’d say Odie’s modifications are split between needs and preferences; and not everyone has the same needs, and certainly not the same prefrences - That’s the difference. (and there aren’t many producing his level of near-perfection either.)
Tim
Tim
Yeah, sort of like buying a sportscar and then spending a few years under the hood, under the frame, and inside the cabin customizing it to your desires, your needs and preferences.
Tim
Yeah....you guys are right.
Not everyone will have the same needs, or desires that I do. I'm adding to this thread strictly for informational purposes. It's intended to be a source of information for those who are contemplating a new lathe purchase.
=o=
Here is a little graph I've made up to find the appropriate hole position for the current diameter bowl. This is for use on the back side of the bowl. On the back side, the hole position is critical for banjo clearance on the front. There is specs for headstock placed at both 0° and 15°.
=o=
I may be wrong, but my theory is that when you really reef hard on steel threads against the much softer cast iron threads, they can become distorted. When this happens, then the union between the two metals is forever changed. Once that change takes place, the holding power between the two metals is likewise forever reduced......and the handle will slip.
=o=
Threaded holes in cast iron are generally considered self-lubricating and fairly durable, but long-term excessive tightening wouldn’t be doing it any favors. Fortunately, there’s several options in the event that a repair is needed. In my opinion, the best (and easiest) is to use a Heli-Coil.
One thing I'm going to miss, is the Minarik controller I had on the Woodfast lathe had an automatic "spindle brake", and therefore only took a second for the spindle to stop. The new Vicmarc doesn't have this, and takes close to 7-8 seconds for the spindle to stop.
I see this as a safety issue. :(
=o=
That must be pre-programmed to help lessen the chances of chucks and faceplates from unscrewing under rapid braking inertia.
Can the drive programming be tweaked to adjust that? Or maybe a simple twist of a screw inside the motor controller? Maybe the controller booklet has instruction.
I'm pretty certain the VFD on my little Oneway allows 2 different braking speeds by way of an external toggle switch. I think.
Long live the 1.5hp Leeson DC and Minarik drive on my 23yo Vicmark VL200. There i$ alway$ the option of $witching over to a DC drive $y$tem on your new lathe. Thi$ wa$ affordable 20 year$ ago, not $o much anymore. Probably north of a thou$and dollar$, I'd bet, but those $etup$ are $till easily found. That particular Minarik drive was good for up to 2hp, if I recall. (See below, over $1500.)
It may not be convenient in every situation, but there is always the handwheel, or as it was known in the olden days, the handbrake.
Technological "advancement", pfft!
Edit-
Amazon is not the best place to buy motors, but here is my Vicmarc 1.5hp DC motor, $1000 now-
And Minarik controller, today's version, $540 from Minarik-
=o=
The default deceleration time is 6 seconds (parameter F08). I’ve adjusted mine to 3 seconds since I am constantly stopping to clear out shavings and measure wall thickness. It was easy once I figured out how to get the drive out of data protection mode. One of the risks of a short deceleration time, besides the chuck possibly unscrewing from the spindle, is braking overvoltage. Essentially, the motor acts as a generator during deceleration, generating voltage that is sent back to the drive. This can cause the drive to trip, preventing damage, and the motor will then coast to a stop. A braking resistor is used to “absorb” that voltage and dissipate it as heat. The Vicmarc has a braking resistor already installed in the circuitry. If I put something big and heavy on and had issues with tripping, I would just adjust the decel time to 4, 5, or even back to 6 seconds. One nice feature of the Oneway is that it has a toggle switch on the side of the control box to select short or long decel time without having to get into the drive. Not sure if that could be added to the Vic.
=o=
Hmm. The acceleration/deceleration times on the PM and Jet lathes with Delta VFDs are set to 5 seconds but that parameter can be changed. They use an electronic brake. Some of the larger lathes with VFDs incorporate a heavy-duty resistor to bleed off the electrical energy generated from decelerating. (My son's new hybrid truck used the motors to slow the vehicle when appropriate - he said there's no evidence so far of the brake pads even touching the disks - may have to turn that down or off occasionally to keep the disks from accumulating rust!)
For me, it's the VERY long slow-down time on my bench grinders with CBN wheels. I think THAT's a safety hazard! What I do is hold a stick of wood inside the thick rim of the wheel and use friction to bring the grinder to a stop in maybe 4 seconds.
If I had a free-running lathe with a long slowdown time I'd consider rigging a stick or even a lever with a leather pad to contact the handwheel and work like a friction brake. I can't imagine that hurting anything.
Jet makes a variable speed bench grinder that incorporates a drive and a brake.
https://jettools.com/ibg-8vs-8in-variable-speed-industrial-grinder
(Edited to insert link to Jet’s website instead of a sellers website)
Dayton and Palmgren have similar models.
Huh, if I didn't already have my Baldor and US-built Milwaukee grinders, I'd strongly consider that Jet VS grinder. Expensive in comparison to Rikon, but not so much when thought of as a long-term investment.
When I mentioned 7-8 seconds, that was a guess while I typed......soooo, I went out this morning to verify.
@600rpm, it takes close to 3.5 seconds to stop.
It'll take longer for a higher rpm, but it's noticeably longer than the Woodfast was with the Minarik drive.
^^^^^ Good idea! I may consider that as a solution. (In the meantime, I've got lots of other things on my mind.)
=o=
That works for free-running coast to a stop, but not for a ramp-down under power. I've observed several woodturners riding the handwheel and thinking that they are helping the lathe slow to a stop. The VFD has a programmed ramp-down profile, and it will follow that profile regardless of friction load (assuming that you can't apply enough friction to overcome maximum motor torque).
The typical six-second ramp-down profile found on most woodturning lathes assumes that the motor was running at full speed. The ramp-down time is proportionally less for slower motor speeds.
Coasting: True, dat!
My elderly no-name 1/2 speed bench grinder will coast for a LONG time, never timed it.
I'll check the PM3520b today with a stop watch to see what difference the initial speed or mass of the piece makes .
When I programmed a VFD for a Jet1642 I set the accel/decel times to the 5 seconds that factory used. (I copied all the parameters in the manual when I bought the lathe.} My PM had the same 5-sec in that field.
@Odie
Regarding your steady rest—or what I’d call a hemi-steady rest since it doesn’t circle the piece—if it were on the other side, couldn’t you then work on the outside and inside of the piece? The way it’s set up, isn’t only inside work possible? How do you use it?
@Odie
Howdy Alan...
The Oneway bowl steady does flip to the other side when necessary. You are correct that theoretically, all the turning could be done with the bowl steady on the back side. I don't do that because I'd rather have the wheels positioned closer to the cutting action of the lathe tool whenever that is possible...
=o=
Any chance I might be able to talk you into a brief turtorial on how you did this. Really straight forward on my Titan.
I’ll just put it here:
(This is for the drive in the attached photo. I bought my VL240 in the fall of 2023, I do not know when they started using this drive, or if they are still using it on newer models)
Press PRG until you see 1.F (the “1” will be flashing)
Press FUNC and you should see F 00.
(If it shows F 01, press the down arrow to get F 00).
Press FUNC again and you will see a flashing 1
(That is the drive protection mode)
Hold STOP and press the down arrow.
The flashing 1 will change to a flashing 0
Press FUNC and you will see SAVE on the display,
Then it will change to F 01.
Press the UP arrow until you see F 08
Press FUNC and you should see 6.00 with the last 0 flashing.
Use the arrows to change to desired decel time (in seconds).
Press Func and you will see SAVE on the display.
Congratulations! You have changed your decel parameter!
If you want to return the drive to protection mode,
Use the arrows to return to F 00, press FUNC and change the flashing 0 to 1 (you’ll have to hold STOP and use the arrows to change this parameter) and press FUNC again to save.
Other lathes and other VFDs will have a different sequence of button pushing and a different designation/number for the parameter for deceleration time, but all of them will have such a setting. In the vfd manual, there will be a chart of parameters. Look for 'deceleration time', 'decel time' or similar. The list or chart will tell you what parameter designation/number you need to change, what the default value probably is, and what value you need to input to get the result you want. (5 seconds +/- seems to be pretty typical for wood lathes. I set the accel time to 10 seconds for the high school students, for a little extra safety factor)
Some vfds will have password protection. This is typical on the Powermatic VFD as it comes from the factory, for example. In that case, you will need to know the password in order to change your parameters. Before entering the password, pause for a moment and give some serious thought to why the manufacturer doesn't want you screwing around with the vfd and whether you know enough to do so.
If you make the acceleration or deceleration times too short, it can cause the vfd to pause itself (and lathe operation), showing a fault or error code. (Explained more authoritatively by Kevin in #250) When that happens, you have to reset the vfd to get the lathe going again. And you should consider increasing the accel or decel time to prevent this in the future.
Odie, knowing what you know now, are you happy with your choice?
Yes....even with the problems I've found, I know of no other lathe that is built specifically for bowl turners like this one. It is a back saver, and when I switch from exterior to interior turning, I don't have to physically move either myself or the setup.....like would be necessary with a sliding headstock.
The engineering of the banjo is my biggest gripe, but I can work with it now that I know it's weak points. I will NEVER overtighten the banjo post clamp.....and, I've made an alternative clamp handle when the lever gets in the way. Even with it's weak points, it's still a very good banjo.
The headstock flange gets in the way of positioning my bowl steady and banjo for some applications......but, I seem to have been able to overcome all obstacles that represents.
I continue to do little modifications that make life easier for me......like these indicator marks facing the front that allows positioning of the headstock a little more accurately from the operator's perspective:
=o=
Note: I don't think I'll ever need to rotate the headstock more than 15°. From my perspective, the only purpose of the rotating headstock is to save your back without relocating your workpiece, the setup, or you.....and that it does quite well indeed! :)
Things just keep getting better and better...... :)
This Birdseye Maple bowl has been on the lathe for 2 weeks now. I stopped to modify some existing jigs and build a couple of new ones!
The two-position bedway table with the blue pool noodle for hip brace has been taking up my time for a few days now.....but, it's done and works as planned.
Making everything work like a well-greased machine is only part of the fun.......now some finished bowls will follow!
This year, some of my techniques and procedures have changed or been modified for the better. The quality of my bowls will be enhanced, and to the well-trained eye, the difference is outstanding!
Shown here is my setup for sanding interiors of my bowls. The bowl interiors are the ONLY place where I use power sanding. The exteriors, rims and footings are all turned to very fine surfaces.....ready for a bare minimum of hand sanding. My usual starting grit is either 240gt or 180gt 95% of the time.....even with the most difficult of very hard/dense exotic woods. The only way this is possible, is to achieve perfect cuts straight from the lathe tool.
=o=
Some of my techniques and procedures have changed or been modified, too. The quality of my bowls will be enhanced, and to the well-trained eye, the difference is outstanding!
=o=
Odie, I mean this in the most supportive way possible. Didn't you get a new lathe? I can't see it for all the accessories. Maybe it walked off. ;)
Looks like everything you need! Could write notes to your loved one, throw a noodle to someone about to drown and even brush your teeth in your finish drying time! 🤔😂
Ha,ha.....yeah, I guess I deserve that. :)
Believe it or not......everything has a purpose, and contributes to the final outcome.
They don't call me the "eccentric old guy" for nuthin..!!!!! :)
=o=
Haven’t seen any recent gorgeous bowls from you!
Ever since Summer, things around here have been changing dramatically. Not only has there been a new lathe to adapt to, I've changed quite a bit of my tooling. Those changes come very slow and often need to be done over and over again until things are right.
On top of that, I've moved my Model A Ford from the storage facility into a new storage shed on my property. It took quite a lot of my time with setting up another shop for this specialized purpose.
I've only made 3-4 bowls since summertime, and every one of them has been a very slow process.....having to stop multiple times to modify and/or make new jigs for one specific purpose.
My time has to be balanced between other circumstances that need my attention....:)
=o=
Odie, you have inspired me to build a bed table for my VL240, just for a couple of sanders (I like your cradles) and some mandrels and things. It will be much more basic than yours.
BTW, I have put a shelf under the bed ways of my VL240 (just a piece of 1/2" ply shaped to fill the space) and find it quite handy for tools and things. The shelf catches some shavings and has to be cleared now and then, but I actually prefer this to having the shavings slide down behind the lathe where, for me, they are hard to clean up.
Odie, you’re in good company. I just watched a YouTube video about Richard Raffan setting up his new Vicmarc VL200.
=o=
View attachment 82847View attachment 82848View attachment 82849
I just miss seeing them. They motivate me. Thanks for the update.
You mean a little table that can slide along the ways? I've made and used several like this, sometimes take them to demos if I know what lathe the club has. The block keeps it from tilting. I usually keep two on the lathe and move them to the left or right of the tailstock as needed. I like to cover them with thin carpet.
BTW, I have put a shelf under the bed ways .... The shelf catches some shavings and has to be cleared now and then, but I actually prefer this to having the shavings slide down behind the lathe where, for me, they are hard to clean up.
What saves me a lot of clean up is a big plastic tub under the lathe. Since I keep my lathes close to the wall the tub is pushed tight against the wall and catches almost everything. Even protects the cutting edge of a dropped tool.
=o=
Odie would you mind going thru and telling us the purpose of all the wooden add ons you have done . It looks like an amazing setup
I could write a book, Gerald!....... :)
What you're looking at is one setup for one specific purpose.....and there are many! There is no magic here with my setups. Everything is made so it's easy to conveniently redo the setup over and over again. The whole purpose is a matter of convenience and repeatability. Many setups are purpose-built to be used in other setups for other tasks.
My setups are unique to me, and are a component in what makes my bowls unique in the world of woodturning.
Besides the setup of the moment, there are things that stay on the lathe permanently......like several kinds of pencils, tool cradles, measurement devices, markers, and so forth.....
=o=
What’s the quarter round in the tailstock for?
That's what I call a "whacker"!
It's used to dislodge crud that builds up within the flute of gouges.
=o=
@Odie what became of your Woodfast? Or rather, what will become if your Woodfast?
