Hello all. I have been following this forum for a long time; but, I have hesitated to join due to having to place my full real name as my forum name. I am somewhat of a private person; but, here is some of the information I would like to share. First of all, thanks you for having me.
I have been woodworking since high school, "majoring" in all the shop classes. I did work as an apprentice in a machine shop while I was in high school, both after school and full time in the summer.
I got back into woodworking in around 1992 or so and did quite a bit for a couple of years as a hobby. Not too much in the way of woodturning during that couple of years, although I did some on my Shopsmith MK V. I then stopped doing it reguarly; except a couple of projects here and there.
I recently retired, and have enjoyed woodworking regularly. I started turning on a regular basis, almost daily, since around March of this year. I started on a Harbor Freight lathe that I no longer have; but, it worked pretty nicely. I then tried a couple of mini/midi lathes, and then acquired another Shopsmith, a 10ER (heavy cast iron beast) that I dedicated as a lathe. It turns rather well. I also have a Nova Comet that I also like. Actually, since acquiring the Nova recently, I have not turned on my Shopsmith, mainly due to trying out my new toy and partialy because of being to lazy to change out the spindle adapter on the chuck.
I like to turn small bowls, boxes, goblets, and spinning tops. I am addicted to turning. I hope to learn plenty on this forum, and hopefully one day have enough knowledge and experience to contribute meaningfully. I strive for a Powermatic 2020 but the main deterrent is the cost which for me would include having to add 220v to my garage shop.
My shop is half a of a 2 car garage. I have a table saw, work bench, the two lathes described above, a Shopsmith 10ER dedicated drill press, jointer, Shopsmith MK V (with Band Saw and Strip sander with SS Power Station, and an older Craftsman Bandsaw. Kind of tight in there; but, I finally, after moving stuff around a few times found a configuartion that works well. I only do woodworking as a hobby.
Regards,
Dan
Regards,
Dan
