Epoxy finish for a shave bowl
Edmonton,AB,Canada
I'm looking for some advice on 2 part mix ratios to apply to a new shaving bowl. I have Wests 2 part epoxy as well as west 2 part epoxy sealer. Any help would be greatly appreciated.
Peoria, Illinois
I wouldn't change the ratio or add thinner, but you could warm the mixing bowl in hot water to reduce the viscosity if you wanted to. Not recommended though if you are using a fast catalyst.
La Grange, IL
Interesting to see that Alumilite can be brushed on. I would think one or two coats of that would be as impermeable to water as any plastic. Is it durable?
Canton, GA
I actually turn with a recess which I usually leave—just sand and finish like the rest of the piece-so it hasn’t been an issue for me—the only issue I have is cost of materials when making a ‘wasted wood bowl’ or mug
