Favorite chuck/jaws for large blank coring
Utah
In reading another thread discussing jaws I wondered what other’s favorite chucks/jaws are for coring really large blanks.
I have the Nova Titan with deep grip jaws - they expand to about 5 1/2” but at that expanded width it is not an ideal hold since the jaws are opened so wide. I have used them many times for 18-22” bowl blanks without problem but recently had an issue. I was coring a 23” very wet blank that was a bit deeper than I’ve ever done before (about 14-15”) and the strain must have been too much as the edges of my tenon kind of crumpled or broke down when I was making the last and largest core, causing the piece to come a little loose and wobble and I had to redo the tenon and take down a lot of the depth of the blank.
For the first two smaller cores I had tailstock support using an extension, but for the largest core it wouldn’t reach the bottom of the second to largest bowl due to the blank depth. I usually core from smallest to largest so that I don’t have to remount but maybe in the future I should just core the largest first then put a tenon on it and remount it to do the smaller blanks. That would let me keep tailstock support the whole time but is a bit inefficient.
While it could have just been the wood (cottonwood which is relatively soft) combined with the heaviness due to it being super wet with a large and deep blank, I wondered if a larger chuck would have helped, maybe with a 6” tenon where the jaws were closed enough for optimal holding.
I was looking at the Vicmarc site and they have dovetail jaws for the VM150 chuck that measure at 4.9”, 5.9”, 6.9”, and 7.9” when optimally closed. I only have Nova chucks now and wanted to avoid the expense of another chuck and different brand but maybe for coring it’s worth getting a Vicmarc as I don’t see anything larger for the Nova Titan than what I have.
I’m curious what others use for coring really large blanks or other advice on how to avoid similar failures.
Thanks, Tom
I routinely core largest to smallest. When I make the starting blank I use a faceplate. I leave that in place when I turn the blank around to core, its good for keeping the tailstock extension in place. After the core is out it is quick to mount it up and cut the new tenon for making the next bowl.
It would be nice to have a tenon cutter that will mount where the coring cutters go though.
I watched Chris Ramsey turn a cowboy hat. He shaped the outside of the blank then used a straight tool to take off an outside ring he saved to dry and later make a round frame. (Removing this gave a head start on turning the hat rim.) Looks like the blank was first mounted on a faceplate, held at first at the tailstock before reversing to finish the turning.
Of course I'm not suggesting you work this way when coring but maybe his sequence could be food for thought.
Almost everyone I've watched turn large pieces for anything held the work with a faceplate. Can be stronger than chuck jaws even if the wood is not perfect.
Largest cores I can do are ~ 14” from a ~15-1/2”bowl, smaller than your application, but I use Oneway Stronghold #5 aluminum profiled jaws that hold well fully expanded at ~6-1/4”.
Did you have the tenon as long as possible w/o bottoming - helps with soft wood and might do the job.
A faceplate could always be used.
Looking at nova’s site I found 2 jaw sets that look to be bigger:
I use 2 Vicmarc 140 chucks. I keep a 5" set on one and a 7" on the other. And if I am turning a very large 18 to 24" I will use the 9"
I usually core ( with a Mcnaughton) , using #4 stronghold jaws. My first cores were done on a harbor freight lathe with 2" benjamin best jaws. I only lost one blank out of the chuck mainly due to punky wood. Probably not recommended but,......
Never thought of doing that but it’s a great idea. Definitely would’ve helped in this case but I think I’ll look at getting some larger jaws too. Thanks!!!
Tom
I use the Nova Titan 6.5" jaws on either of my Nova Titan or Nova Titan III chucks. The Titan 6.5" and the Titan 5.75" jaw sets are two of the best jaw sets ever made by Nova.
Amazon had a package with both the Nova 5.75” and 6.6” jaws that I just ordered. I was a bit confused because on the Nova chart shown below the largest listed (titan powergrip) goes up to only 5.42” for tenons. I didn’t realize they had larger jaws not on the chart.
Thanks for the replies and guidance. I’m excited to try these new jaws on the many blanks I just processed measuring 20-23”.
Tom
I use a recess for all of my coring, with the McNaughton system, most of the time, the medium curve blade from the medium set of blades. I use a recess, always. I almost never turn bowls over about 14 inch diameter because they don't sell well. The recess I use is about 2 5/8 inch diameter, and usually about 1/8 inch deep.
I will be demonstrating for our club on Thursday. I do have, and will demo all 3 coring systems, Woodcut, Oneway, and McNaughton. I still prefer the McNaughton. One of the early demos when our club first formed, I asked if anyone had the McNaughton and actually knew how to use it, and that was our next demo. I took it and ran with that.
Doug are the #5 and #6 jaws for the Stronghold dovetailed? I currently use the #4 jaws but need larger jaws for some applications. I see places online that say the #5 and #6 are dovetailed and other that say they are just smooth.
I plan to buy another Stronghold or Vicmarc chuck.
Thanks!
To address your original query, in case others don't have larger Nova jaws on order, I was advised to use the largest jaws possible when I first learned coring. The mentor used 5-6" jaws on his non-Nova chucks. The Powerjaws that came with my Nova Titan chuck (it may be a Titan II) are about 100mm for a recess and 75mm on a tenon, which I believe is too small, plus their length gets the blank farther out from the headstock. Instead, I use the bowl jaws which are the same diameter as the Titan chuck, and I believe use a 5" (125mm) recess or a 4" tenon. They're not as big as my mentor's, but they have proven reliable with either the McNaughten or OneWay coring systems.
The original Nova Titan came with the 5" power grip jaws (a deep jaw). The Nova Titan II came with the 4" power grip jaws these were the same jaws you could use on the Supernova II (this was the only piece of equipment I gave a not so sterling review of when I was writing articles). Not because it was a bad chuck but it was a step down from the Titan as it took the 2 hole jaws (so you could use the entire 2 hole jaw product line but all the other chucks already did that). Soon there after Nova came out with the Nova Titan III which once again comes with the 5" power grip jaws. Then finally after all those years they came out with the 6.5" and 5.75" dovetail jaws. Thank you!
I have always started my coring by starting with a screw and make the tenon and turned side. I would then take the biggest core. I then put it back on the screw and made another tenon and repeated the process doing that until finished. I think from now on I will core small to biggest as I probably wasted a ton of time and energy which I now find dwindling as I age.
I usually start the way you do on a screw, making the first tenon, then core the biggest core first and leave the original blank on the lathe and use as a jam chuck, just reversing the core and cutting a tenon around the live center.
Edited to add: using the McNaughton system.
I have been very happy with the heavy duty dovetail jaw sets for the Vicmarc 120 chucks starting with their V00679 173mm which has a dovetail of 16mm depth, which spreads the grip load over a far larger area than others I used before getting Vicmarc chucks.
The next size up is the V00680 198mm jaw set, which also has a 16mm dovetail depth.
Their biggest (which I don't have) is the V00682 223mm jaw set, this jaw set has an 18mm dovetail depth.
My experience with the V00679 and V00680 jaw sets, is that if you carefully match the dovetail of the jaw set to very close to the maximum dept and the jaws are running a gap of around 5mm with wet wood, you should be alright.
With very wet wood, you need to allow for compression as you are turning and losing water at a great rate, hence the minimum of a 5mm gap to allow for tightening the jaws somewhat.
In my earlier days of turning extremely wet wood, I tended to take huge cuts, which was fun and fast. However the downside became apparent when removing the blank and seeing the crack lines starting to appear at the base of the dovetail on the blank. By lessening my cuts I now rarely get crack lines appearing on the dovetails after gouging or coring the blank.
I have the Woodcut coring system.
Well, my Nova 5 3/4” and 6 1/2” jaws came but they are not as big as I thought they were. The Nova website doesn’t clearly state their ranges and I stupidly thought the sizes of the chucks were the ranges. I actually already have the 6 1/2” chuck jaws but they only do about a 4.5” tenon with good support.
Here is a picture of the actual jaws in approximately ideal positions for tenons:
The manuals that came with them state the range for tenons is only 87-116 mm (3.4-4.5”) and 99-133 mm (3.9-5.2”).
I was hoping to find a chuck with 6-7” for tenons for all the large, wet cottonwood blanks I’ve got. I either have to get another brand of chuck or find a more stable way of coring. Maybe I’ll try the methods mentioned here by starting with the largest core first, leaving the faceplate on so it is ready to flip and make a tenon. Otherwise I fear that once I get one Vicmarc chuck I’ll want to replace all my Novas and that would be expensive!!!
Thanks to everyone for your suggestions and input. I love this journey even though it seems like I’m often just stumbling along.
Tom
Thanks, Tom
Most of my chucks are of the Titan range and more of less are my go to jaws
  • 70mm (2.75") & 100mm (4") Bowl Jaws: Ideal for expanding into a bowl's internal recess or contracting onto a footed spigot, with a specific dovetail profile to prevent wood fiber crushing.
  • Long Nosed Jaws (75mm): These jaws have a high rise (2" above the base) for reaching deep inside bowls or vessels, offering excellent internal and external holding power for green wood turning
  • PowerGrip Jaws: Often included as standard with the Titan chuck, these are heavy-duty jaws (typically 100mm/4" or 130mm/5") designed for large spigot and hollow form turning, providing maximum holding power for substantial projects
If you would like to save money, look at the woodturningstore.com and the Hurricane HTC125 chuck and jaws. I have used 3 of the HTC chucks and an assortment of jaws for about 10 years and have experienced no problems.
Extra Large Dovetail Jaws:
Jaw Dimensions in the CLOSED position: Compression Mode 5 1/4"; Expansion Mode 6 1/2"
Jaw Dimensions in the OPEN position: Compression Mode 6 5/8"; Expansion Mode 8 3/8
Chuck and above Jaws about $250
Tom
For future reference, chuck jaws 'size' is generally the OD of the jaws when closed. The ID will always be less, and depends on the width of the jaws.
Thomas it's not just the opening size with these jaws it's also the thick wide flat walls for the piece to sit on that makes them better. This makes it a lot less likely that the piece will pull or twist out of these jaws. If I was coring the biggest piece of wood that fits on my Powermatic you can be sure these are the jaws I would be using.
As I tend to turn the outside to a finished state and then hold it by the foot to turn the inside. I pick my jaws to fit the design size of the foot rather than any thing else.
The Nova jaws 70mm (2.75") & 100mm (4") Bowl Jaws: come with additional holes with thier low profile jaws are my most oten choice here as the come with additional m6 tapped holes. I have made up 3 sets of small aluminium jaws 35-40-45 dia's for very small feet to turn boxes like my avatar
Ad far as I know, the htc125 chuck with the extra large jaws are the biggest dovetail jaws you can get outside of vicmarc for tenon size.
I have one and use it often, and do think the extra size is a big asset, reducing vibration on big cuts significantly.
I will note that it came with some issues. They are insert chucks and there was some difficulty getting the insert in due to some burrs and very close tolerance. The bigger issue was the jaw slide faces not running true. They were tilted, like fan blades I suppose is the way to describe it. Was able to lap them flat and they perform well now, but obviously not ideal.
Could well be. Oneway has a set for the Stronghold chuck #6, out of AL, that have their patented profile shape, a serrated jaw with a curve design at the corners to increase hold with jaws expanded. For a tenon they are 6-1/8 to 7-3/8. I have a set of their #5, same as the #6 a bit smaller. Have used them fully expanded to hold while coring with no issues. I routinely use various sizes of there profile jaws (I use their tower jaws the most) to hold work with jaws expanded out without issues.
