Home built outboard bowl turning lathe $750
Status
Not open for further replies.
Deliverence, GA
It can handle 200-300 lab blanks when anchored and ballasted. Motor is 220v 3hp, 3ph, 1800rpm inverter rated with adjustable base and matching VFD. The spindle is 1-15/16 chrome-moly, threaded 1-1/2-8tpi Bearing races are rated 6000 lbs. Table is 1/2 corten plate and weighs 600 lbs. I can no longer lift heavy blanks. Everything is basically brand new. $750 (about 1/2 of what I have in it. All grade 8 fasteners. Currently disassembled and in storage. Needs a belt guard. I can load it easily. 912-269-2423 dermoosundsquirrelgmail .combl-1.JPGbl-2.JPGbl-2.JPGspalted maple.JPGVFD Drive.JPG
Located 15 miles South of Jesup, GA Tim 912-269-2423
Status
