Homemade Threading Jig
Whenever I see a demo of a threading jig with the demonstrator not using a climb cut his credibility goes down to near zero for me. In post #22 I saw this. Also he did an equally stupid thing using the point of his caliper to mark a diameter on a spinning piece (he even warned about the danger doing this).
I've used my threading jigs abd tried climb cuts. I see no difference whatsoever. The reason is the cutters we use not shaped like you show in your photo. They are v shaped.
the following are my first two responses from Google.
Yes google can be handy, thanks. Some may not know the difference and the why.
My ebony didn't care when threading, or if it did, it didn't make a fuss. But that's just the way ebony is.
I REALLY love the B&W stuff. No finish needed.
My woodturning prayer: "Grant me the wisdom not to waste my remaining B&W ebony stock. And please send more."
The image I posted earlier is only really representative of flat work.
The contact area when cutting a thread on a box is smaller and does not have the same amount of support suggested for climb cutting on flat work.
Unless you feed the box onto the cutter at a high rate of revolutions per minute (neither practical or desirable) I believe the difference between conventional and climb cutting for End Grain boxes is minimal. This must go part way to explain why some of us have seen no difference.
Side Grain Boxes are however another matter.
I think this image displays the difference a bit better.
Nice diagram. I believe the same.
But, Ha! I might consider someone who fine threads side (face) grain boxes (and expects them to open and close gracefully from now on) an Optimist. Or maybe, a Wizard.
I sometimes use climb cutting on the milling machine for the final pass for a better finish, where that is useful, especially with aluminum and brass. No grain issues!
Hmm, I understand climbing cuts on the table saw and with a router, but not on the thread cutters. The teeth come to points, not hooks like a saw blade. I was thinking maybe you meant starting at the top and cutting to the base of the thread, or starting at the bottom and working your way to the top, if that makes sense.
One of my forst* attempts with my homemade jig was a climb cut. I was feeding very slowly, and it was light cut, but I had forgotten to crank up the spindle speed. It was an exciting moment when to tried to pull my turned wood handwheel from my paws. :oops:
A climb cut will make a nice cut, but it has to be controlled. A good example of an uncontrolled climb cut is feeding a board from the wrong side of a table saw.
(* This was a typo, but it works for a first/worst attempt)
Not quit sure I understand your post. When you mention photo do you mean the diagram Bill Alston posted?
The shape of the cutter has nothing to do with whether the cut is climb or not. V tooth or whatever tooth shape has nothing to do with the situation, the direction of feed with respect to direction of cutter rotation is the determining factor.
Are you sure you were climb cutting? That would require starting the thread cut inside the lid and cranking the jig in reverse.
You saw no difference ? There are no guarantees there will be a difference. Do you disagree with the Google responses I posted?
There's another issue wiht using threading jigs. That's whether the cutter is neutral rake or positive. The cutters supplied with the Klein jig were neutral rake, positive would be much better.
In my previous post I talked about neutral and positive rake cutters. Here's a link to a neutral rake cutter from chefware.
The way to tell is imagine a plane from the face of a cutter tooth extending to the cutter center. If the plane passes the through the center it's neutral. If it's positive it'll pass above the center.
Verify what I'm saying by looking at a quality router bit from the cutting end, the plane will not pass through the center. Positive bits are more expensive and make better cuts. Same thing with wood cutting table saw blades (neutral & negative rake are for metals usually).
The issue with threading cutters is none seem to be available in positive rake in the diameter needed except carbide ones that are in hundred$.
I don't agree at all. I cut tenons on end grain blanks all the time on the CNC using the tenons for holding in collets. The climb cut tenons are usually much cleaner cuts especially in softer woods.
Those who don't notice much difference may be choosing woods that cut well both ways. Or liberal application of CA glue can make normally poor wood act nice.
Fast forward to 15:30 and In this side grain box video Ronald Kanne says “The cutter and the box are in opposite directions which gives a much better cut”. Timber is London Plane so the finishing cuts are reinforced with cyanoacrylate glue. The cutter used looks like the standard one supplied with the jig which are neutral rake.
As a point of interest, 60° positive rake cutters like this one are commonly available from China. You obviously need a suitable arbor to go with it.
From what I’ve seen, it’s not uncommon for the male thread to be cut in the opposite direction to the female thread. You don’t have to do it this way but I feel it’s a little easier. This is another example.
I don’t know the source of the statements above, but regarding climb cutting, this part isn’t correct:
Yeah, I have to agree with you on that part of the Google response. But, anyway the consensus opinion seems to be climb cutting is better.
Do you climb cut on your ellipse machine?
While we're talking about cutting clean threads... I once used a 90 degree cutter instead of 60 degree. It give a stronger thread form with less tendency to chip the crests off. No law says turners you have to use 60 degree.
I primarily climb-cut on my ellipse machine. Occasionally I’ll cut conventionally on light finishing passes.
The cutter being used in the threading video is a 90 degree profile with a radiused root.
Tim
On the other end of the threading spectrum, here’s a view of my set-up cutting a 2tpi thread. Bois D’Arc wasn’t a good choice since it’s so brittle. I could have flipped the die grinder around to climb, which would have helped prevent some of the chipping.
View: https://youtu.be/ab173hf02DY
Tim
This is a 2.5"-2 thread standard 60 degree in hard maple done in 1989 on a 12" Delta lathe. The lead screw at 4 TPI Acme thread was mounted in 2" height blocks and linked to the head stock spindle via chain and sprockets with a 2 to 1 ratio. The router drove a 60 Degree cutter ithe the tip blunted to produce about a 1/16" flat to cut the male thread. The female thread was cut on the axis of the bed with a side cut as is done with all of the current jigs. The reason I set up to cut the thread was a request to make a bench screw, but the customer decided to use a steel screw instead, so I made this lamp.
This is my current setup using a metal lathe with a wide range of pitches down to 4TPI. This is a climb cut on a finial lid similar to the lid on the urn in my avatar. The climb cut as I am using it is completely controlled at a steady rate of feed and with the chasing dial the feed can be disengaged and re engaged as often as needed to finesse the fit. The only thing done different than cutting threads in metal is the router mounted to the top slide. I have an adapter to mount the woodturning chuck on the metal lathe since the normal wood turning is done better on the wood lathe.
Where did you find the adapter? (did you make it?)
Several times I’ve wished I had one.
My 1950's vintage LaBlond lathe came with a set of 4C collets, the set included 2 dead centers and since the only use for them is if needed for driving a piece of stock with a lathe dog. I sacrificed one of them to make my adapter to do that I cut the point off press fit a piece of steel on there and proceeded to machine the 1.25 - 8 male thread.
The photos illustrate how I accomplished it but it is obvious that you could not do it the same way. The most practical method for you is probably to make an adapter similar to the ones available to convert the 1.25" - 8 to 1" - 8, but that all depends on how your accessories like chucks or faceplates attach to your metal lathe.
Thanks for the ideas. I've only removed the 3-jaw chuck once in the last half-dozen years so I'll examine the options. Having that capability would have made it unnecessary turn down some steel chuck jaws on the wood lathe with hand tools - it worked fine but was not the most favorite thing I've ever done!
Nice thread. Damn seasonal movement.
Tim
The seasonal movement is why the coarse pitches, generally no finer than 10TPI, should be used along with greater tolerance so that the thread will not bind due to radial expansion during the summer heat and humidity.
The adapter does work great for that some of the jobs that I used it for was to remove the bird beak on the outside of the profile jaws on my OneWay chuck jaws. Note when doing that I installed the wood worm screw, which turned out to be the proper spacing for machining the perfect circle.
I built this item to quickly align a Hope threading jig. There is a flat plate on the Hope jig that the wood aligner butts up to. 2 screws in bottom board help make a good fit in lathe ways. Simply loosen the jig on the post and slide the wood aligner up to back, align and tighten the post lock. Ignore the level and wood dowel - used early on to make sure the face of the wood aligner was correctly perpendicular to bed ways.
Wishing you good luck on building your own jig. You certainly are getting lots of good help here.
I was referring to the lamp base...
Tim
OK I should have known better even back then to not make the base and the shelf the way that I did. The maple used was purchased from a hardwood dealer in Minneapolis and was likely kiln dried so if you ask a kiln operator what the wood was dried to they will tell only what it was on leaving the kiln.
The shrinkage rates for sugar maple is 9.9% tangential and 4.8% radial, that is from green to oven dry. The wood will always try to reach equilibrium with it's environment and that is what you get when you don't allow for that seasonal change.
I do the same, sometimes climb milling on my manual mill leaves a better finish, sometimes conventional.
Hi Bill. I am new here & saw your earlier picture of the Hope jig mounted on the lathe between center points. My question is, can you have the jig locked in the the banjo & both headstock & tailstock center points seated perfectly into the indents of the threader spindle? I can't do it with mine. If I line up the tailstock center, the headstock end of the threading spindle is 2.1mm below center point. The head & tail stock line up perfect & the banjo is spot on 90 degree to the bed. Simon seems to think it's within spec. Me, not so much. Is your cutter very close to the horizontal center of the piece you are threading? I believe the problem is the weld joint connecting the main body. The big problem is I bought it 3 years ago & just got around to using it. It also means that with my cutter being 4-6mm above center the click calculations he has wont be the same & it won't be a perfect thread being on an slight angle to the work piece. I look forward to your reply. Thanks Dwayne.
The first thing I did was to set the jig between centres with the banjo unlocked from the bed, and the jig stem loose in the hole in the banjo.
Step two was to set the locking collar on the top of the banjo and lock it in place. This is important to be able to mount the jig repeatedly at centre height.
Mounting the jig between centres for subsequent sessions is just to square the banjo to the bed ways. It’s not by any means a necessary step. You can just eyeball the jig to the bed ways as Simon Hope shows in his videos.
I did mention my method to Simon though and he said it was a good idea and that he’d amend his instructions.
The only thing is the post on my jig is square to the body & spindle. So even with it in the banjo the spindle isn't parallel to the lathe bed. The chuck end is 2.1mm lower than the crank end.
the banjo post mount is perfect 90 degree to the bed. Both ends of the cylinder wont line up with live centers at the same time.
What lathe have you got? I ask as there was one particular model a while back that was supplied with banjos that didn’t have the hole drilled perpendicular to the base. This meant the top of the tool post was noticeably at an angle to the bed.
Replacements were sent out under warranty. Could this be the cause of the issue you’re experiencing?
That’s curious. I can only assume that the jig itself is off somehow? There are actually three versions of the jig. All of them are slightly different. I have what I would call the mark 3 version, which was the latest when I bought it some time last year.
Edit: I’m not sure it would help, but do you have a picture of your jig so we can see what version it is?
It is the MK2 & I bought it 3 years ago but just got around to using it a week ago. It is has the built in hinge, not the hinge plate that was added onto the original.
I have taken it apart & checked out the shaft, hinge & body. All of the machined parts seem to be good. I believe the problem is spindle housing is welded to the other part that slides when you adjust for the threading.
I think it wasn't quite lined up when welded. With that making the check end of the spindle 2+mm lower than the crank end. That's over 7".
how close to dead center is your cutter to your work piece?
I’ve put a centre in the head stock spindle and dropped the jig into the banjo and locked it off. Swivelled at an angle to show the alignment.
Edit: I didn’t check the tail end was still aligned with the tail stock, but provided it’s not more than a couple of mm’s out it shouldn’t make too much of a difference?
Yes mine is out by 2+mm over the length of the spindle being 180mm. If i line up at the head stock & threading a box that is 180mm + chuck being 100mm it would be out 3+mm above center of the box. It would also slightly change the shape of the threads. That then continues to increase the longer the box you are threading. I am sure his calculations for the # of clicks a based on the cutter being centered in the box. If the cutter should be centered it makes the stopper ring on the shaft useless as you would have to adjust the height between threading the box & the lid. In my mind anyway. Thanks for the picture.
It sounds like your assumption of the welding being off may be correct. I’ll try to double check mine and see if it’s high or low at the tailstock end. I’ve only cut a couple of box threads - nothing over about 10mm long, and didn’t notice any issues.
I’m guessing it would show up on longer threads though if it’s off too far.
