My Jet Mini lathe varible speed is making a noise.
I have had the lathe a number of years, but do not use it that much. I brought it to Florida with me this winter and have been using it frequently for the past month. When home, I typically only use it for buffing as I have a larger lathe I work on.
The noise is a low squealing type noise, and I cannot tell if it is the belt, or a motor bearing. Sounds like a belt rubbing the side of the wheel, but why would it start doing that?
Anyone had problems with motor bearings going out on Jet mini's?
Any ideas on what this could be? It is not the drive bearings, but could be in the motor or the belt.
I plan to keep using it until something "happens" and then I will know if it is the belt or something more serious.
I always assumed the Jet mini is pretty bulletproof.
e
e
