Oneway Coring Setup
Status
Not open for further replies.
Eagle Idaho
Oneway Coring with 3 blades and stabilizers, base unit, 3-cutters and height adjusting rods and bolts.
Also includes gig for sharping cutters. Unit is in like new condition. handle included. freight is not included.
It was used on a Robust A/B
$ 490.00
lench5040@gmail.com
For what it‘s worth, there’s a solid round metal bar inside the base that works with the 25 1/2“ lathe. This post can be removed by loosening a set screw to cut shorter (by 1/2“ to 3/4”) and reinserted to work with a 24” lathe setup.
Perfect that s what I needed. I have a 20 inch lathe so it would not work.
The outer cylinder (tube) on the base is hollow all the way down to the base plate on my 24” setup. Thus, I would think both the outer cylinder and the removable inner post could be cut down to fit on a smaller lathe. A metal cutting bandsaw could make quick work of this. Just ask around the forum or check with Oneway for the height measurements for a 20” lathe.
Status
